中国兽医学报
CHINESE JOURNAL OF VETERINARY SCINECE
2000 Vol.20 No.1 P.55-57
水浴湿法消化Zeeman石墨炉
原子吸收法
测定肉鸡肝组织中硒含量
杨保收 陈越 金久善 王若军 王宗义
摘要:采用水浴湿法消化,以Pd(NO3)2-Triton X -100作为基体改进剂,应用Zeeman石墨炉
原子吸收法测定了肝组织硒含量。试验结果表明 ,肝组织经水浴湿法消化测得的硒含量与消化炉湿法消化测定结果基本一致(P>0.05), 相对标准偏差为1.11%,回收率为95.80%~100.40%。石墨炉
原子吸收法测定硒的检测限 为5.0 μg/L。
关键词:硒; 湿法消化; 石墨炉
原子吸收法
中图分类号:S854.4 文献标识码:A 文章编号:1005-4545(2000)01-0055-03
Determination of Selenium Content in Broiler Liver with Wet Digestion i n Boiling Water Bath by Zeeman Graphite Furnace Atomic Absorption Spectrometry
YANG Bao-shou
(Faculty of Veterinary Medicine,Inner Mongolia University of Agriculture & Animal Husband ry, Huhehot 010018, China)
CHEN Yue, JIN Jiu-shan
(College of Veterinary Medicine, China Agricultural Universit y,Beijing 100094,China)
WANG Ruo -jun, WANG Zong-yi
(Ministry of Agriculture Feed Indusrty Center,Beij ing 100094,China)
Abstract:The broiler liver was digested by the nitric/perc hloric acids in boiling water bath and the selenium was determined by Zeeman gr aphite furnace atomic absorption spectrometry (GFAAS) after addition of Pd(NO3 )2-Triton X-100 as a matrix modifer. The results demonstrated that the selen ium contents in the liver digested with the acids in boiling water bath were not different from those in heating block (P>0.05) with the relative standard d eviation and recovery rate to be 1.11% and 95.80%-100.40% respectively, and the detection limit of selenium for GFAAS to be 5.0 μg/L.
Key words:selenium; wet digestion; graphite furnace atomic absorption spectrometry
基金项目:国家自然科学基金资助项目(39570538)
作者简介:杨保收(1962~ ),男,副教授,博士。
杨保收(内蒙古农牧学院 动物医学系, 内蒙古 呼和浩特 010018)
陈越(中国农业大 学 动物医学院, 北京 100094)
金久善(中国农业大 学 动物医学院, 北京 100094)
王若军(农业部饲料工业中心, 北京 100094)
王宗义(农业部饲料工业中心, 北京 100094)
参考文献:
[1] Welz B, Melcher M. Determination of selenium in human body fluids by hydride-generation atomic absorption spectrometry[J ].Analytica Acta, 1984, 165:131~140.
[2] Bernhard Welz.
原子吸收光谱法[M].第2版.李家熙译.北京:地质出版社 ,1989.369.
[3] L′vov B V. The analytical use of atomic absorption spectra[J].Spectr ochim Acta, 1961, 17B:761.
[4] 田笠卿,黄振钟,陈逸土 君,等.等温 平台无焰塞曼
原子吸收直接测定血清中硒的研究[J].环境化学,1989,8(4):41~45.
[5] 任建成,邴建生,朱 丽,等.Zeeman石墨炉
原子吸收法测定大青叶合剂中硒[J ].理化检验化学分册,1998,34(6):252~253.
[6] 任建成,王怀友,张晓凯,等.石墨炉
原子吸收法测定饮料中硒[J].光谱学与 光谱分析,1997,17(4):92~95.
收稿日期:1999-02-14
