原文由 zhengchao5211 发表:
The verification of compliance with the specific migration limits provided for in paragraph 1 may be ensured by the determination of the quantity of a substance in the finished material or article provided that a relationship between that quantity and the value of the specific migration of the substance has been established either by an adequate experimentation or by the application of generally recognised diffusion models based on scientific evidence.
是关于食品迁移的
先谢谢了
是否符合第一段给出的特定迁移限值,可以通过测定成材或成品中某种物质的含量来确认。但前提是,该物质测定数值与特定迁移数值之间的关系需要通过充分的实验确认或通过基于科学依据的、被普遍(一致,一般??)认可的分散模型所确定。
