主题:【原创】马来酸酐如何用GC进行分析
浏览0 回复5 电梯直达
arez206
请问大家马来酸酐如何用GC进行分析?
arez206
mavisw_1101
Dillute in ethyl acetate or ethanol , nitrogen dryness, add 200uL BSTFA+TMCs(99:1) inject to gc inject volumn 1ul,
gc Temperature Program
Initial temperature: 80°C, increased at a rate of 10°C min-1 until 250°C
Injector / detector temperature: 250°C / 300°C
Carrier gas: Helium (Splitless in the first minute)
gc-FID
arez206
thank you very much!
another question is what kind of column will be used?
guoqifen
最好还是用液相色谱作,否则重组分对色谱系统有污染。如用GC,在稀释样品的时候最好加入硅烷化试剂
mavisw_1101
