这个是标准溶液混标的方案,适用于ICP的,你可以参考下。
ICP多元素混标 23种
ICP multi-element standard solution XVI (21 elements in diluted nitric acid) 100 mg/l:Sb, As, Be, Cd, Ca, Cr, Co, Cu, Fe, Pb, Li, Mg, Mn,Mo, Ni, Se, Sr, Tl, Ti, V, Zn CertiPUR
ICP multi-element standard solution IX (9 elements in dilute nitric acid) 100 mg/l: As, Be, Cd, Cr(VI), Hg, Ni, Pb, Se, Tl CertiPUR
