主题:【求助】请教:dynamic injection phase和static elution phase是什么意思啊?
浏览0 回复32 电梯直达
zhl009zhl009
该帖子已被ruojun设置为精华;
如题; 最近看论文出现的,我不太熟悉这些术语,不知道具体是什么意思?哪位可以给个详细点的解释.此外,这些东西有什么用处呢? 请指教!!!!!
高卧东山
静态洗脱相?没听说过
这个词儿是哪上面的?有上下文么?
zhl009zhl009
Many analytical methods are based on liquid chromatography
and typically the only measure of system stability
is standards, injected repeatedly throughout the sequence.
In this paper, a novel approach is presented,
where the analytical run is treated as a process with the
chromatographic data as the product. It is postulated that
enhanced quality of the data can be obtained through
monitoring the process, i.e., the chromatographic system,
during the sequence. For this purpose, a liquid chromatography
process control (LCPC) system has been developed.
Here, several parameters, e.g., the pressure at the
column and the injection valve, are monitored. Chemometrics
is used for interpreting the data and producing
multivariate statistical process control (MSPC) charts. The
chromatographic run is divided into two parts: the
dynamic injection phase and the static elution phase. Two
principal component analysis (PCA) models, one for each
phase, are continuously created and upgraded as the data
are collected. The results of the PCA are shown in the
MSPC charts, and when an error detection limit is
exceeded, the analyst is promptly notified. LCPC, a
continuous system suitability test, provides better control
of the analysis, allowing a reduction in the number of
standards and replicates. Furthermore, troubleshooting
is facilitated.
zhl009zhl009
闲鹤野云
看了一下原文,是否可以这样理解:
dynamic injection phase 动态进样阶段
和static elution phase 静态洗脱阶段
对两个液相分析的过程进行质量检测来找出一个合适的质控方法。我给你放到专业英语版,看其他专家的理解如何。
happyjyl
字面上看同意ruojun的翻译。不过我们只有液相方面的基础知识,建议楼主还是到液相版问问。
闲鹤野云
原文由 happyjyl 发表:
不行先放在专业英语,然后请液相的专家来给诊断一下么
JazzBlue
何当奇
原文由 sezilu 发表:
流动相
固定相
感觉应该是这样的
就是不知道跟mobile phase 和Stationary Phase有什么区别?
高卧东山
这个地方的phase当如ruojun所说,翻译成“阶段”,原文第三页也有说明
happyjyl
原文由 sezilu 发表:
流动相
固定相
这里的phase明显是指色谱分析的两个阶段,不是指流动相和固定相。
