主题:【资料】水泥词汇
浏览0 回复3 电梯直达
醋老西
该帖子已被happyjyl设置为精华; 奖励积分记录: happyjyl(5分)
矿渣水泥slag cement
硅酸盐水泥portland cement
主导产品leading product
年产量annual output
基准reference
体系system
完全燃烧complete combustion
不完全燃烧incomplete combustion
机械不完全燃烧mechanical incomplete combustion
化学不完全燃烧chemical incomplete combustion
雾化atomization
雾化介质atomizing medium
物料平衡material balance
实际空气量amount of actual air for combustion
理论空气量amount of theoretical air for combustion
理论烟气量amount of theoretical burned gas; amount of theoretical flue gas
形成热heat of formation
单位热耗unit heat consumption
标准煤Standard coal
标准煤耗standard coal consumption
实物煤耗raw coal consumption
窑炉的余热利用waste heat utilization of kiln
干燥周期drying cycle
焙烧周期firing cycle
热损失thermal loss; heat loss
燃烧热heat of combustion
有效热effective heat
热效率 heal efficiency
燃烧效率 combustion efficiency
一次空气primary air
二次空气secondary air
系统漏入空气量false air
空气系数air coefficient
废气含尘浓度dust content in stack gas
热平衡表heat balance table
热流图heat balance diagram
回转窑rotary kiln
窑胭体内容积 inside volume of kiln shell
窑胴体有效内表面积 effective inside surface of kiln shell
窑或预热器排出飞灰量 dust emit out from the Kiln or preheater system
入窑回灰量 dust fed back into kiln system
飞损飞灰量 amount of flying loss of dust
生料中可燃物质 combustible components in raw meal
生料带入空气量 air volume carrying by raw meal
冷却机烟囱排灰量 dust content emitting from stack of cooler
煤磨从窑系统抽出的热气体量 hot gas volume from Kiln system for coal mill
入窑回灰脱水及碳酸盐分解耗热 heat consumption for dehydration and decarbonation for dust fed back into kiln system
回转窑用煤应用基coal used in rotary kiln system
立窑shaft Kiln
漏风系数 false air coefficient
普通立窑cement shaft Kilt / ordinary shaft Kiln
机械化立窑mechanized cement shaft kiln
立窑喇叭口inversed cone inlet of shaft kiln
立窑单位截面积产量production of shaft kiln for unit cross section
立窑单位容积产量production of shaft Kiln for unit volume
干白生料耗consumption of drying raw meal
立窑断面平均风速average velocity in cross section of shaft kiln
卸料管漏出风量amount of leaked out air for discharging tube
窑面废气成分composition of combustion gas at the upper in surface of shaft Kiln
黑生料black meal
入磨煤量internal fuel amount of raw meal
半黑生料semi-black meal
入窑煤量external fuel amount of raw meal
隧道窑tunnel Kiln
倒焰窑down draft kiln
检查坑道inspection pit
预热带preheating zone
烧成带firing zone; burning zone
冷却带cooling zone
窑车kiln car
匣钵sagger
棚板deck
气幕air curtain
直接冷却direct cooling
间接冷却indirect cooling
窑尾冷风cooling gas in the kiln outlet
窑内断面温差difference of temperature in cross section of kiln
进车间隔时间kiln car time schedule
坯体内结构水含量structural water content in body
坯体的入窑温度inletting body temperature
零压面neutral margin
轮窑annular Kilt / ring Kilt circular kiln
窑门wicket
隧追式干燥室tunnel dryer
湿坯wet green
干坯dried green
绝干坯absolute dried green
普通砖common brick
窑的部火数number of fire travels in annular kiln
内掺燃料(简称内燃料)carbonaceous materials added to raw materials
外投燃料(简称外燃料)external fuel added into firing-hole of a kiln
焙烧反应热heat of burning reaction
操作放热损失heat losses in the opening and closing of kiln wicket and firing holes
隧道式干燥室-轮窑(隧道窑)体系热效率(简称体系热效率)(ηtx)
the fmal efficiency of tunnel dryer-annular kiln (tunnel kiln)system
隧道式干燥室-轮窑(隧道窑)体系单位热耗(简称体系单位热耗)
unit heat consumption of tunnel dryer-annular Kiln(tunnel kiln)system
隧道式干燥室,轮窑(隧道窑)体系单位煤耗(简称体系单位煤耗)(mtxm)
unit coal consumption of tunnel dryer-annular Kiln(tunnel kiln)system
路漫漫而求索
精华帖怎么现在还没有人来捧场啊?!
我先顶一下!
nature1981
zllboy
