IPC/JEDEC-9702 Monotonic Bend Characterization of Board-Level Interconnects
平板互连的单一弯曲特性
IPC-PD-335 Electronic Packaging Handbook
电子封装手册
IPC-7525 Stencil Design Guidelines
网版设计导则
IPC-QL 365A Certification of Facilities That Inspect/Test Printed Boards, Components and Materials
印制板, 元件和材料检验/试验企业的授证
IPC-9191 General Guidelines for Implementation of Statistical Process Control
统计过程控制导则
IPC-TR-581 IPC Phase III Controlled Atmosphere Soldering Study
IPC第3阶段受控气氛焊接研究
IPC-MI-660 Incoming Inspection of Raw Materials Manual
原材料接收检验手册
IPC/EIA J-STD-004A Requirements for Soldering Fluxes-Includes Amendment 1
锡焊焊剂要求(包括修改单1)
IPC/EIA J-STD-005 Requirements for Soldering Pastes-Includes Amendment 1
焊膏技术要求(包括修改单1)
IPC-HDBK-005 Guide to Solder Paste Assessment
焊膏性能评价手册
IPC/EIA J-STD-006A Requirements for Electronic Grade Solder Alloys and Fluxed and Non-Fluxed Solid Solders 电子设备用电子级锡焊合金、带焊剂及不带剂整体焊料技术要求
IPC-SM-817 General Requirements for Dielectric Surface Mounting Adhesives
表面安装用介电粘接剂通用要求
ELEC-SOLDER Modern Solder Technology for Competitive Electronics Manufacturing
电子制造的最新焊接技术
IPC-WP-006 Round Robin Testing & Analysis: Lead-Free Alloys-Tin, Silver, & Copper
无铅焊料合金锡-银-铜的试验和分析求
IPC-CA-821 General Requirements for Thermally Conductive Adhesives
导热胶粘剂通用要求
IPC-3406 Guidelines for Electrically Conductive Surface Mount Adhesives
表面贴装导电胶使用指南
IPC-3408 General Requirements for Anisotropically Conductive Adhesives Films
各向异性导电胶膜的一般要求
IPC-CC-830B Qualification and Performance of Electrical Insulating Compound for Printed Wiring Assemblies
印制板组装电气绝缘性能和质量手册
IPC-HDBK-830 Guideline for Design, Selection and Application of Conformal Coatings
敷形涂层的设计,选择和应用手册
IPC-SM-840C Qualification and Performance of Permanent Solder Mask - Includes Amendment 1
永久性阻焊剂的鉴定及性能(包括修改单1)
IPC-HDBK-840 Guide to Solder Paste Assessment
焊膏性能评价手册
ELEC-MICRO Handbook of Lead Free Solder Technology for Microelectronic Assemblies
微电子组装无铅焊接技术手册
IPC-TP-1114 The Layman’s Guide to Qualifying a Process to J-STD-001
基于J-STD-001组装工艺雷氏选择法
IPC-AJ-820 Assembly & Joining Handbook
装联手册
IPC-7530 Guidelines for Temperature Profiling for Mass Soldering (Reflow & Wave) Processes
大规模焊接(回流焊与波峰焊)过程温度曲线指南
IPC-TP-1090 The Layman’s Guide to Qualifying New Fluxes
新型助焊剂雷氏选择法
IPC-TP-1115 Selection and Implementation Strategy for a Low-Residue No-Clean Process
低残留不清洗工艺的选择和实施
IPC-S-816 SMT Process Guideline & Checklist
表面安装技术过程导则及检核表
IPC-TR-460A Trouble-Shooting Checklist for Wave Soldering Printed Wiring Boards
印制板波峰焊故障排除检查表
IPC-CM-770E Component Mounting Guidelines for Printed Boards
印制板元件安装导则
IPC-7912A Calculation of DPMO & Manufacturing Indices for Printed Board Assemblies
印制板和电子组装件每百万件缺陷数(DPMO)和制造指数的计算
IPC-9261 In-Process DPMO and Estimated Yield for PWAs
印制板组装过程中每百万件缺陷数(DPMO)及合格率估计
IPC-DPMO-202 IPC-7912/9261 End Item and In Process DPMO Set
IPC-7912A 和IPC-9261合订本
IPC-9500-K Assembly Process Component Simulations, Guidelines & Classifications Package
组装过程中元件仿真, 规则分类
IPC-9501 PWB Assembly Process Simulation for Evaluation of Electronic Components 电子元件的印制板组装过程模拟评价
IPC-9502 PWB Assembly Soldering Process Guideline for Electronic Components
电子元件的印制板组装焊接过导则
IPC-9503 Moisture Sensitivity Classification for Non-IC Components
非集成电路元件的湿度敏感度分级
IPC-9504 Assembly Process Simulation for Evaluation of Non-IC Components (Preconditioning Non-IC Components)
非集成电路元件的组装过程模拟评价(非集成电路元件预处理)
IPC-9850-K Surface Mount Placement Equipment Characterization-KIT
表面贴装设备性能检测方法的描述(附Gerber格式CD盘)
IPC-9850-TM-KW, IPC-9850-TM-K Test Materials Kit for Surface Mount Placement Equipment Standardization
表面贴装设备性能测试用的标准工具包
• 4 IPC-9850 Placement Accuracy Verification Panels
• 1 IPC-9850 CMM Measurement Verification Panels
• 150 IPC-9850 QFP-100 Glass Components
• 130 IPC-9850 QFP-208 Glass Components
• 150 IPC-9850 BGA-228 Glass Components
• NIST Traceable Measurement Certificate
• Custom Storage Case
IPC-7711/21A 电子组装件的返工与返修
IPC/EIA J-STD-002B Solderability Tests for Component Leads, Terminations, Lugs, Terminals and Wires
元件引线、端子、焊片、接线柱及导线可焊性试验
IPC/EIA J-STD-003A Solderability Tests for Printed Boards
印制板可焊性试验
IPC-TR-461 Trouble-Shooting Checklist for Wave Soldering Printed Wiring Boards
印制板波峰焊故障排除检查表
IPC-TR-462 Solderability Evaluation of Printed Boards with Protective Coatings Over Long-term Storage
带保护性涂层印制板长期贮存的可焊性评价
IPC-TR-464 Accelerated Aging for Solderability Evaluations
可焊性加速老化评价(附修订)
IPC-TR-465-1 Round Robin Test on Steam Ager Temperature Control Stability
蒸汽老化器温度控制稳定性联合试验
IPC-TR-465-2 The Effect of Steam Aging Time and Temperature on Solderability Test Results
蒸汽老化时间与温度对可焊性试验结果的影响
IPC-TR-465-3 Evaluation of Steam Aging on Alternative Finishes, Phase IIA
替代涂覆层的蒸汽老化评价
IPC-TR-466 Technical Report: Wetting Balance Standard Weight Comparison Test
技术报告: 润湿天平称重标准对比测试
SMC-WP-001 Soldering Capability White Paper Report
可焊性工艺导论
SMC-WP-005 PCB Surface Finishes
印制电路板表面清洗
