第十九章 经典
液相色谱法
薄层色谱法:TLC
吸附:adsorption
活化:activation
脱活性:deactivation
交联度:degree of cross linking
交换容量:exchange capacity
薄层板:thin layer plate
展开剂:developing solvent ,developer
临界胶束浓度:criticak micolle concentration ,CMC
相对比移值:relative Rf, Rr
分离度:resolution ,R
分离数:separation number,SN
煅石膏:Gypsum
羧甲基纤维素钠:CMC-Na
吸收光谱联用:TLC-UV
薄层色谱-荧光联用:TLC-F
薄层色谱-红外吸收光谱联用:TLC-IR
薄层色谱法:TLC-MS
纸色谱法:paper chromatography
上行展开:ascending development
下行法展开:descending development
双向展开:two dimensional develoooment
第二十章
气相色谱法
气相色谱法:gas chromatography
前延峰:leading peak
拖尾峰:tailing peak
对称因子:symmetry factor,fs
保留时间:retention time
保留体积:retention volume
死时间:dead time
调整保留时间:asjusted retention time
半峰宽:peak width at half height,W1/2 or Y1/2
峰宽:peak width,W
等温线:isotherm
理论塔板高度:height equivalent to atheoretical plate
化学键合相:chemically bonded phase
丁二酸二乙二醇聚酯:polydiethylene glycol succinate,PDEGS,DEGS
高分子多孔微球:GDX
苯乙烯:STY
乙基乙烯苯:EST
二乙烯苯:DVB
涂壁毛细管柱:wall coated open tubular column,WCOT
载体涂层毛细管柱:supprot coated open tubular column,SCOT
热导检测器:thermal conductivity detector,TCD
氢焰离子化检测器:hydrogen flame ionization detector,FID
电子捕获检测器:electron capture detector ,ECD
噪声:noise,N
漂移:drift,d
灵敏度:sensitivity
检测限(敏感度):detectability,D,M
分离度:resolution
归一化法:normalization method
外标法:external standardization
第二十一章 高效
液相色谱法
高效
液相色谱法:high performance liquid chromatography,HPLC
高速
液相色谱法:high speed LC,HSLC
高压
液相色谱法:high pressure LC,HPLC
高分辨
液相色谱法:high resolution LC,HRLC
液固吸附色谱法(液固色谱法):liquid-solid adsorption chromatography,LSC
液液色谱法:liquid-liquid chromatography,LLC
正相:normal phase,NP
反相:reversed phase,RP
化学键合相色谱法:bonded phase chromatography,BPC
十八烷基:octadecylselyl,ODS
离子对色谱法:paired ion chromatography,PIC
反相离子对色谱法:RPIC
离子抑制色谱法:ion suppression chromatography,ISC
离子色谱法:ion chromatography,IC
手性色谱法:chiral chromatography,CC
环糊精色谱法:cyclodextrin chromatography,CDC
胶束色谱法:micellar chromatography,MC
亲和色谱法:affinity chromatography,AC
固定相:stationary phase
化学键合相:chemically bonde phase
封尾、封顶、遮盖:end capping
手性固定相:chiral stationary phase,CSP
恒组成溶剂洗脱:isocraic elution
梯度洗脱:gradient elution
紫外检测器:ultraviolet detector,UVD
荧光检测器:fluorophotomeric detector,FD
电化学检测器:ECD
示差折光检测器:RID
光电二极管检测器:photodiode array detector ,DAD
三维光谱-波谱图:3D-spectrochromatogram
蒸发光散射检测器:evaporative light scattering detector,ELSD
安培检测器:ampere detector,AD
高效毛细管电泳法:high performance capillary electrophoresis,HPCE
淌度:mobility
电泳:electrophoresis
电渗:electroosmosis
动力进样:hydrodynamic injection
电动进样:electrokinetic injection
毛细管区带电泳法:capillary zone electrophoresis,CZE
胶束电动毛细管色谱:micellar electrokinetic capillary chromatography,MECC
毛细管凝胶电泳:capillary gel electrophoresis,CGE
筛分:sieving
绪论
释药系统(drug delivery system,DDS)
中国药典(Chinese Pharmacopoeia,ChP)
美国药典(The United States Pharmacopoeia,USP)
美国国家处方集(The National Formulary,NF)
英国药典(British Pharmacopoeia,BP)
欧洲药典(European Pharmacopoeia,Ph.Eup)
国际药典(The International Pharmacopoeia,Ph.Int)
良好药品实验研究规范(Good Laboratory Practice,GLP)
良好药品生产规范(Good Manufacture Practice,GMP)
良好药品供应规范(Good Supply Practice,GSP)
良好药品临床试验规范(Good Clinical Practice,GCP)
分析质量管理(Analytical Quality Control,AQC)
第1章 药物的鉴别试验
药物的鉴别试验identification test
一般鉴别试验general identification test
专属鉴别试验specific identification test
灵敏度sensitivity
最低检出量minimum detectable quantity
最低检出浓度minimum detectable concentration
第2章 药物的杂质检查
巯基醋酸mercaptoacetic acid
古蔡Gutzeit
二乙基二硫代氨基甲酸银siliver diethyldithio-carbamate
硫酸灰分sulphated ash
炽灼残渣residue on ignition
热重分析法thermogravimetric analysis,TGA
差示热分析法differential thermal analysis,DTA
差示扫描量热法differential scanning calorimetry,DSC
碱性酒石酸铜试验Fehling’s reagent
异红紫酸盐isopurpurate
2,3-二氨基萘2,3-diaminonaphthalene
4,5-苯并苯硒二唑4,5-benzopiazselenol
第三章 定量分析样品前处理与测定方法的效能指标
汞齐化法amalgamation method
氧瓶燃烧法oxygen flask combustion method
葡萄糖醛酸甙glucuronides
硫酸酯sulphates
血浆plasma
血清serum
全血whole blood
治疗药物浓度监测therapeutic drug monitoring,TDM
结合bound
游离free
缀合物conjugate
液-液提取法liquid-liquid extraction,LLE
离子对试剂ion pair reagent
离子对提取法ion pair extraction method
反离子counter
液-固提取法liquid-solid extraction LSE
半自动样品制备系统advanced automated sample processor,AASP
烷基化alkylations
酰基化acylations
硅烷化silylations
精密度precision
标准差standard deviation,SD orS
相对标准差relative standard deviation,RSD
变异系数coefficient of variation,CV
批内精密度within-run precision
日内精密度within-day precision
批间精密度between-run precision
日间精密度day to day precision
准确度accuracy
定量限limit of quantitation,LOQ
检测限limit of detection,LOD
选择性selectivity
专属性specificity
线性与范围linearity and range
重现性ruggedness
耐用性robustness
散布图scatter diagram
荧光偏振免疫测定法fluorescence polarization immunoassay,FPIA
第4章 巴比妥类药物的分析
溴化十六烷基三甲基苄铵cetyltrimethylbenzylammonium bromide,CTMA
氯化四癸基二甲基苄铵Tetradacyldimethybenzylammonium chloride,TDBA
第5章 芳酸及其酯类药物的分析
苯甲酸及其钠盐benzoic acid and sodium benzoate
布美他尼bumetanide
羟苯乙酯ethylparoben
丙磺舒probenecid
酚黄乙胺etamsylate
第6章 胺类药物的分析
第七章 杂环类药物的分析
二硝基氯苯反应Vongerichten反应
戊烯二醛反应K?nig反应
第8章 生物碱类药物的分析
生物碱alkaloids
阿片gum opium
扫尾剂tailing-suppressing reagent
蒂巴因thebaine
诺司卡品noscapine
竞争离子competing ions
亲脂性lipophicity
拖尾因子tailing factor
金刚烷adamantane
第9章 维生素类药物的分析
维生素vitamin
我英语不好,自己看也累的上,拿来和大家分享,有需要的尽管点
