原文由 yuyi 发表:
A robust plasma can be obtained when using a low nebulization gas flow-rate, an elevated radio frequency power, and a central injector tube with an internal diameter equal to or larger than 2.0 mm.
怎么我看有的书说频率的提高会降低光源的稳健性的,是不是与上面的说法有出入?这里的an elevated radio frequency power指的是什么呢?
