这里有两篇外文的资料,只有摘要,您可以看看,有没有帮助,如需要全文可以去文献求助-应助版面。
Optimized method for the determination of organophosphorus pesticides in meat and fatty matrices
RenéK. Juhler
Journal of Chromatography A Volume 786, Issue 1, 24 October 1997, Pages 145-153
Abstract
A method was developed and optimized for determination of residues of organophosphorus pesticides (OPs) in meat and fatty matrices. The method was developed for the national Danish monitoring programme, whereby priority was given to simplify the clean-up, avoid use of toxic and harmful organic solvents and allow quantification at ppb level using
gc with nitrogen-phosphorus detection (NPD). Homogenized meat was extracted using ethyl acetate, the co-extracted water being removed using anhydrous Na2SO4. The clean-up was done through fat precipitation by cooling the extract flowed by solid-phase extraction on C18 mini-columns. Pesticide residues were determined by
gc-NPD using a DB1701 capillary column. The limit of detection was 1 to 20 ppb and limit of determination was 2 to 33 ppd and the method is feasible for control of fat-soluble OPs according to the maximum residue limits set by the European Communities. The method developed covers a broad polarity range from polar OPs, such as acephate and methamidophos, through medium polar OPs to non-polar pesticides, such as prothiofos.
Low-temperature clean-up method for the determination of organophosphorus insecticides in olive oil
Lentza-Rizos, , a, E. J. Avramidesa and Frédérique Cherasco
Volume 912, Issue 1, 30 March 2001, Pages 135-142
Abstract
A simple, extremely low-cost method using low-temperature lipid precipitation has been developed for the rapid analysis of virgin olive oil for organophosphorus insecticides and triazine herbicides commonly used in olive groves. The method gives good clean-up for
gc analysis with nitrogen–phosphorus detection and recoveries between 77 and 104%, with RSD values of 7–16%. Matrix enhancement was observed for some pesticides and metabolites.
