原文由 zlf99056 发表:
是最低检出限,即单位时间内载气携带被测物质进入检测器的克数 我们刚做完这个问题
One more question, (FID)
The FID detection limitation ( g/s) is : 2NW/A.
N is the Baseline noise (A)
W is the Mass of n-Hexadecane (g)
A is the Average area amount of n-Hexadecane ( A• s)
So, how to calculate the Baseline Noise (A)?
(1) The Noise (N: peak to peak) is measure over a representative section of baseline equal to 20 times the width of the analyte peak ( Wi).
(2) When the instrument is under optimal conditions that produce a continuous, electronic output, the Noise ( N ) may be measured from the Peak to Peak Variation ( N: peak to peak) in the baseline signal.
N = N:peak to peak.
