Depth of investigation 调查的程度
It is important to point out that by itself, an alert provided by a method designed to detect unexpected events or degradation patterns is no proof that the batch in question has a deviating trend. The alert is only a signal to begin an investigation. The alert is not intended to make any conclusions. A conclusion can only be reached after the investigation of OOT stability data that follows.
这一点很重要,就是用检测非期望事件或降解方式的方法提出警戒,不是证明讨论批有背离趋势。警戒只是启动调查的一个信号。警戒不是要做出什么结论。只有接下来对OOT稳定性数据进行调查以后才可以做出结论。
An investigation's depth may depend on the nature of the data, the product history and characteristics being measured, the potential risk to product quality, and the potentially related safety or efficacy implications. The CGMP regulations in CFR 211.166 require an assessment of drug stability, whereas 21 CFR 211.192 requires an investigation of unexplained discrepancies by the quality control unit.
调查的程度取决于数据的性质,产品历史和所检测的特性,对产品质量的潜在风险以及对有关安全性和有效性的潜在影响。CFR 211.166 的CGMP 法规要求对药品稳定性做出评估,而21 CFR 211.192 要求质量控制部门对不明原因的差异进行调查。
If an analytical alert is observed, a laboratory investigation may be performed. If the laboratory investigation is inconclusive, then the supervisor may take no further action at that time and monitor subsequent time points closely. A review of results for related or correlated test attributes also can facilitate the investigation. Depending on the product, history, and nature of the analytical alert data, the company may decide to investigate whether a manufacturing error occurred in cases in which a laboratory error is not conclusive. More data (i.e., the next stability test point) may be needed to indicate whether the result is part of a long-term trend (process control alert) or just an isolated result. If subsequent results within the study and across other studies are not out of trend, then the initial analytical alert result may be an isolated incident that requires no further investigation.
如果观察到的是分析警戒,应进行实验室调查。如果实验室调查没有结论,主管人当时可以不采取进一步措施,但是要密切检测后面的时间点。有关检测属性的结果审核也有助于调查。根据产品,历史和分析警戒数据的性质,在确定不是实验室误差的情况下,公司可以决定调查是否存在生产误差。可能需要更多的数据(如下一次稳定性测试点的数据)来说明该结果是否是长期趋势(工艺控制警戒)的一部分或者仅仅是一个孤立结果。如果该研究以后的结果和其他的横向结果都没有超出趋势,那么最初的分析警戒有可能就是一个孤立事件,没必要对其做进一步的调查。
A process control alert may indicate unexpected changes in product or assay performance. A stability study with an unusual trend may reveal that a characteristic's stability profile changed, whereas multiple analytical alerts may suggest that the measurement process is no longer in control. When a process control alert is evident, the investigation will often begin with an assessment of the effect of potential changes to the laboratory process (e.g., changes in instrument, column, integration technique, or standard). It also may extend to the manufacturing process (e.g., looking for changes in materials, personnel, equipment, and procedures).
工艺控制警戒可能预示产品或分析性能的意外变化。有着不同寻常趋势的稳定性研究可能显示某一特性的稳定情况发生了改变,而多重分析警戒可能暗示测量过程不再受控。当工艺控制警戒很明显时,调查通常从评估实验室工艺可能存在的变化的影响开始(例如仪器的变化,色谱柱的变化,集成技术的变化,标准的变化等 )。也可延伸到生产工艺(如检查材料,人员,设备和工艺有无变化)。
Because a compliance alert identifies a situation in which a particular study (or several related studies) may not meet specification limits during the expiration period, one may need to conduct a thorough investigation. In general, this investigation begins with the laboratory process and expands to the manufacturing process if no conclusive laboratory root cause is identified. The manufacturing investigation might include other batches (from the same or related products) that may be associated with this predicted failure to identify whether the discrepancy is isolated or systematic. The investigation also could assess whether more analytical testing, an investigation into the manufacturing process, a product recall, or shorter dating is required. An investigation of a compliance alert aims for the early detection of potentially failing product and the identification of possible causes. If a root cause is determined, then appropriate action should be taken such as the identification of potential preventative actions.
因为符合性警戒是指某一特定研究(或一些相关研究)在有效期内可能不符合质量标准限度,因此需要进行全面彻底的调查。通常这种调查从实验室工艺开始,如果不能最终确定根本原因,进一步扩大到生产工艺。生产调查可能会包括与本次预示性失败有关的其他批次(同一产品或相关产品),以确定这种偏差是孤立的还是系统的。调查也要评估是否需要进行另外的分析检测,生产工艺调查,产品召回和减短检测间隔。符合性警戒调查的目的是及早发现潜在的失败产品和确定可能引起失败的原因。如果确定了根本原因,应采取适当的措施,例如确定可能采取的预防措施。
