The Length of 1 Kg of Spring Steel Strip
SK-5 & AISI-301 每公斤长的重量/公斤(阔100-200公厘) Weight per one meter long (kg) (Width 100-200mm)
SK-5 & AISI-301 每公斤之长度(阔100-200公厘) Length per one kg (Width 100-200mm)
SK-5 & AISI-301 每公尺长的重量/公斤(阔2.0-10公厘)
Weight per one meter long (kg) (Width 2.0-10mm)
SK-5 & AISI-301 每公斤之长度(阔2.0-10公厘)
Length per one kg (Width 2.0-10mm)
高碳钢片 High Carbon Steel Strip
分类
Classification
用组织结构分类
Classification According to Grain Structure
用含碳量分类 – 即低碳钢、中碳钢及高碳钢
Classification According to Carbon Contains
弹簧用碳钢片
CarbonSteel Strip For Spring Use
冷轧状态 Cold Rolled Strip
回火状态 Annealed Strip
淬火及回火状态
Hardened & Tempered Strip/ Precision – Quenched Steel Strip
贝氏体钢片 Bainite Steel Strip
弹簧用碳钢片材之边缘处理 Edge Finished
淬火剂
Quenching Media
碳钢回火 Tempering
回火有低温回火及高温回火
Low & High Temperature Tempering
高温回火
退火 Annealing
完全退火 Full Annealing
扩散退火 Diffusion Annealing
低温退火 Low Temperature Annealing
中途退火 Process Annealing
球化退火 Spheroidizing Annealing
光辉退火 Bright Annealing
淬火 Quenching
时间淬火 Time Quenching
奥氏铁孻回火 Austempering
马氏铁体淬火 Marquenching
高碳钢片用途 End Usage of High Carbon Steel Strip
冷轧高碳钢 – 日本工业标准
Cold-Rolled (Special Steel) Carbon Steel Strip to JIS G3311
电镀金属钢片 Plate Metal Strip
简介 General
电镀金属捆片的优点
Advantage of Using Plate Metal Strip
金属捆片电镀层
Plated Layer of Plated Metal Strip
镀镍 Nickel Plated
镀铬 Chrome Plated
镀黄铜 Brass Plated
基层金属 Base Metal of Plated Metal Strip
低碳钢或铁基层金属
Iron & Low Carbon as Base Metal
不锈钢基层金属 Stainless Steel as Base Metal
铜基层金属
Copper as Base Metal
黄铜基层金属
Brass as Base Metal
轴承合金 Bearing Alloy
简介
General
轴承合金 – 日工标准 JIS H 5401
Bearing Alloy to JIS H 5401
锡基、铅基及锌基轴承合金比较表
Comparison of Tin base, Lead base and Zinc base alloy for Bearing purpose
易溶合金 Fusible Alloy
焊接合金 Soldering and Brazing Alloy
软焊 Soldering Alloy
软焊合金 – 日本标准 JIS H 4341
Soldering Alloy to JIS H 4341
硬焊 Brazing Alloy
其它焊接材料请参阅日工标准目录
Other Soldering Material
细线材、枝材、棒材
Chapter Five Wire, Rod & Bar
线材/枝材材质分类及制成品
Classification and End Products of Wire/Rod
铁线(低碳钢线)日工标准 JIS G 3532
Low Carbon Steel Wires ( Iron Wire ) to JIS G 3532
光线(低碳钢线),火线(退火低碳钢线),铅水线 (镀锌低碳钢线)及制造钉用低碳钢线之代号、公差及备注
Ordinary Low Carbon Steel Wire, Annealed Low Carbon Steel Wire, Galvanized low Carbon Steel Wire & Low Carbon Steel Wire for nail manufacturing - classification, Symbol of Grade, Tolerance and Remarks.
机械性能
Mechanical Properites
锌包层之重量,铜硫酸盐试验之酸洗次数及测试用卷筒直径
Weight of Zinc-Coating, Number of Dippings in Cupric Sulphate Test and Diameters of Mandrel Used for Coiling Test
冷冲及冷锻用碳钢线枝
Carbon Steel Wire Rods for Cold Heading & Cold Forging (to JIS G3507)
级别,代号及化学成份
Classification, Symbol of Grade and Chemical Composition
直径公差,偏圆度及脱碳层的平均深度
Diameter Tolerance, Ovality and Average Decarburized Layer Depth
冷拉钢枝材
Cold Drawn Carbon Steel Shafting Bar
枝材之美工标准,日工标准,用途及化学成份
AISI, JIS End Usage and Chemical Composition of Cold Drawn Carbon Steel Shafting Bar
冷拉钢板重量表
Cold Drawn Steel Bar Weight Table
高碳钢线枝
High Carbon Steel Wire Rod (to JIS G3506)
冷拉高碳钢线
Hard Drawn High Carbon Steel Wire
(to JIS G3521, ISO-84580-1&2)
化学成份分析表
Chemical Analysis of Wire Rod
线径、公差及机械性能(日本工业标准 G 3521)
Mechanical Properties (JIS G 3521)
琴线(日本标准 G3522)
Piano Wires ( to G3522)
级别,代号,扭曲特性及可用之线材直径
Classes, symbols, twisting characteristic and applied Wire Diameters
直径,公差及拉力强度
Diameter, Tolerance and Tensile Strength
裂纹之容许深度及脱碳层
Permissible depth of flaw and decarburized layer
常用的弹簧不锈钢线-编号,特性,表面处理及化学成份
StainlessSpring Wire – National Standard number, Charateristic, Surface finish & Chemical composition
弹簧不锈钢线,线径及拉力列表
Stainless Spring Steel, Wire diameter and Tensile strength of Spring Wire
处理及表面状况
Finish & Surface
各种不锈钢线在不同处理拉力比较表
Tensile Strength of various kinds of Stainless Steel Wire under Different Finish
圆径及偏圆度之公差
Tolerance of Wire Diameters & Ovality
铬镍不锈钢及抗热钢弹簧线材 –
美国材验学会 ASTM A313 – 1987
Chromium – Nickel Stainless and Heat-resisting Steel Spring Wire – ASTM A313 – 1987
化学成份 Chemical Composition
机械性能 Mechanical Properties
305, 316, 321及347之拉力表
Tensile Strength Requirements for Types 305, 316, 321 and 347
A1S1-302 贰级线材之拉力表
Tensile Strength of A1S1-302 Wire
日本工业标准 – 不锈钢的化学成份(先数字后字母排列)
JIS – Chemical Composition of Stainless Steel (in order of number & alphabet)
美国工业标准 – 不锈钢及防热钢材的化学成份
(先数字后字母排列)
AISI – Chemical Composition of Stainless Steel & Heat-Resistant Steel(in order of number & alphabet)
易车碳钢
Free Cutting Carbon Steels (to JIS G4804 )
化学成份 Chemical composition
圆钢枝,方钢枝及六角钢枝之形状及尺寸之公差
Tolerance on Shape and Dimensions for Round Steel Bar, Square Steel Bar, Hexagonal Steel Bar
易车(快削)不锈钢 Free Cutting Stainless Steel
易车(快削)不锈钢种类 Type of steel
易车(快削)不锈钢拉力表
Tensile Strength of Free Cutting Wires
枝/棒无芯磨公差表 (μ) (μ = 1/100 mm)
Rod/Bar Centreless Grind Tolerance
易车不锈钢及易车钢之不同尺寸及硬度比较
Hardness of Different Types & Size of Free Cutting Steel
扁线、半圆线及异形线
Flat Wire, Half Round Wire, Shaped Wire and Precision Shaped Fine Wire
加工方法
Manufacturing Method
应用材料
Material Used
特点
Characteristic
用途
End Usages
不锈钢扁线及半圆线常用材料
Commonly used materials for Stainless Flat Wire & Half Round Wire
扁线公差
Flat Wire Tolerance
方线公差
Square Wire Tolerance
