主题:【求助】一句话翻译…27
浏览0 回复9 电梯直达
chengjingbao
我先将这段整体贴出,然后询问,以便大家能理解题意。没有提问的地方,各位有时间也替我找找毛病。谢谢!
9.0 ANALYSER MAINTENANCE分析仪维护
The K4000NG requires very little maintenance. If the analyzer is equipped  with a trap (O2 or H2), this trap should be replaced ON in a periodic base. The frequency of replacement is a function of the sensitivity of the instrument i.e. if the instrument working range is 0-1 ppm or 0-200 ppm. Most of the time for high ppm range (>100 ppm) the trap is not required.
分析仪的维护量非常小,如果分析仪需要配置一个捕集阱(O2 or H2),
这个阱将被安装在一个定制的基座上。阱的置换频率是这个装置的一个敏感要素。如果这个装置的工作量程是0…1 ppm或0…200 ppm。在大多数情况下,测量高量程(>100 ppm),捕集阱是不需要的。
The sample inlet moisture trap can be regenerated by following the instructions included with this trap. If the analyzer is used for process monitoring (distillation column, etc.) you may replace it once a year. In truck loading station, where the moisture level is high due to the use of quick connectors, it is a preferable to regenerate or replace it every six months. These are only guide lines and frequency of replacement may be extended or shorten based on experience. Both traps (O2 or H2) and moisture are available from Contrôle Analytique.
通过包括这个干燥器的如下说明,样品气入口的干燥器可以再生。如果分析仪用于程序控制(分裂蒸馏塔等),一年后你可能要换它。
在连接这个方面,使用快速接头,潮湿度高,它可取的地方是每六个月再生和替换它时的方便操作。这只是一个指导原则,置换频率的处长和缩短要看实际情况。两个捕集阱和干燥器应用于CA的仪器上。
The other parts of the system where maintenance is required are the diaphragm valves. Under normal condition, the valve's diaphragm should be replaced every two years.
系统的其它部分的维护如隔膜阀的维护也是必须的。在正常条件下,阀的隔膜每两年需要更换一次
该帖子作者被版主 何当奇3积分, 2经验,加分理由:有效求助
chengjingbao
第一段最后一句:Most of the time for high ppm range (>100 ppm) the trap is not required.
Most of the time 是什么意思?
第二段中间的短句:In truck loading station是什么意思?
Last edit by chengjingbao
小鸟飞翔
原文由 chengjingbao 发表:
Most of the time 大多数情况下
该帖子作者被版主 redanqi2积分, 2经验,加分理由:应助
poorlittle
直译是货车(货物)起卸站, 这和你的仪器联系得上吗?  若无关, 要看看那个地方the moisture level is high 并且有quick connectors了。
Last edit by poorlittle
chengjingbao
原文由 poorlittle 发表:
这是安装在样品气管线上的干燥器,有硬接头连接,也有用快速插头连接的。分析仪器气路跨接上多用此接头。接头又分为通用接头和专用接头。
题意是指若使用快速接头,其密封性不如硬连接,干燥剂容易失效。
happyjyl
我觉得应该是this trap should be replaced on a periodic base.--捕集阱应定期更换。
可按照说明再生样品气入口的干燥器。
这里的following不是指“如下”(形容词),而是指“按照”(动词),因为前面有个介词by,所以这里要用ing形式。
included with this trap是指说明书是随干燥器一起装入的,这里可以不译。
moisture trap译为干燥器可能是你们的行话,意译也是可以的。
是每年更换一次,而非一年后更换。
每隔六个月再生或更换一次更可取。/最好每隔六个月再生或更换一次。
这里的preferable不是指“可取”,而是指“更可取”。它其实是在拿“每隔六个月再生或更换一次”和前面提到的“每年更换一次”作比较。it is a preferable to do sth = you'd better do sth = it would be best to do sth字面上看意思不大一样,实际上用法是一样的。
隔膜阀也需要维护。
该帖子作者被版主 redanqi5积分, 2经验,加分理由:应助
happyjyl
the moisture level is high 是指“湿度高”。至于truck loading station,倒真是不知道放在这里是什么意思。你这是什么仪器啊?说明书中有没有提到用于哪些工作场所?如果前面提到了,那么也许就是poorlittle所说的那个意思。Anyway,它在那句话里不是重点,不知道意思也没什么影响,只要知道在湿度高的地方再生或更换频率应更高就是了。
chengjingbao
原文由 happyjyl 发表:
还是K4000那台表,这是第九章,维护部分:truck loading station,的意思我明白啦!!!它是指接头连接的位置,即拆卸位置!哪里的湿度污染较高。卸货即拆卸!
HAPPY1点评太好啦!你照你的思路点评,我照我的思路整理。有岐见,我也会讲的。谢谢!三个人的意见我改了8处,收获不小!
poorlittle
两个捕集阱和干燥器应用于CA的仪器上。
If the traps and moisture xxx are not standard parts of your equipment, but optional accessories, the above probably means:
上述之两个捕集阱和干燥器, Contrôle Analytique 公司均有提供。
Available : 可提供; 有存货, 可供选购
chengjingbao
两个捕集阱和干燥器应用于CA的仪器上。
这样就对啦,我还纳闷,难道这几样东西也是外委的,CA专卖。原来它能提供备件。询过价:一样8W.
