怎么没有人响应啊,我发些资料上来吧。
电炉(electric furnace;electric hot plate;electric stove) 四人一个
分析化学:analytical chemistry
定性分析:qualitative analysis
定量分析:quantitative analysis
物理分析:physical analysis
物理化学分析:physico-chemical analysis
仪器分析法:instrumental analysis
流动注射分析法:flow injection analysis;FIA
顺序注射分析法:sequentical injection analysis;SIA
化学计量学:chemometrics
绝对误差:absolute error
相对误差:relative error
系统误差:systematic error
可定误差:determinate error
随机误差:accidental error
不可定误差:indeterminate error
准确度:accuracy
精确度:precision
偏差:debiation,d
平均偏差:average debiation
相对平均偏差:relative average debiation
标准偏差(标准差):standerd deviation;S
相对平均偏差:relatibe standard deviation;RSD
变异系数:coefficient of variation
误差传递:propagation of error
有效数字:significant figure
置信水平:confidence level
显著性水平:level of significance
合并标准偏差(组合标准差):pooled standard debiation
舍弃商:rejection quotient ;Q
滴定分析法:titrametric analysis
滴定:titration
容量分析法:volumetric analysis
化学计量点:stoichiometric point
等当点:equivalent point
电荷平衡:charge balance
电荷平衡式:charge balance equation
质量平衡:mass balance
物料平衡:material balance
质量平衡式:mass balance equation
酸碱滴定法:acid-base titrations
质子自递反应:autoprotolysis reaction
质子自递常数:autoprotolysis constant
质子条件式:proton balance equation
酸碱指示剂:acid-base indicator
指示剂常数:indicator constant
变色范围:colour change interval
混合指示剂:mixed indicator
双指示剂滴定法:double indicator titration
非水滴定法:nonaqueous titrations
质子溶剂:protonic solvent
酸性溶剂:acid solvent
碱性溶剂:basic solvent
两性溶剂:amphototeric solvent
无质子溶剂:aprotic solvent
均化效应:differentiating effect
区分性溶剂:differentiating solvent
离子化:ionization
离解:dissociation
结晶紫:crystal violet
萘酚苯甲醇: α-naphthalphenol benzyl alcohol
奎哪啶红:quinadinered
百里酚蓝:thymol blue
偶氮紫:azo violet
溴酚蓝:bromophenol blue
配位滴定法:compleximetry
乙二胺四乙酸:ethylenediamine tetraacetic acid,EDTA
螯合物:chelate compound
金属指示剂:metal lochrome indcator
氧化还原滴定法:oxidation-reduction titration
碘量法:iodimetry
溴量法:bromimetry ]
溴量法:bromine method
铈量法:cerimetry
高锰酸钾法:potassium permanganate method
条件电位:conditional potential
