主题:【讨论】pengmu版友询问我帮助的一段英语翻译,大家给看看,翻译的如何,帮助修改一下
浏览0 回复5 电梯直达
闲鹤野云
Microwave-assisted extraction (MAE) was used to extract the organic acid from eucalytus. The technological condition was studied with orthogonal design. The extraction solvent, microwave power and irradiation time were investigated to try to find out the best extraction condition. Samples were analyzed with a capillary electrophoresis system to calculate the yield. When extracting with 200ml of anhydrous ether for 6 minutes,assisted by medium-power microwave,the extraction process is optimal and the average recovery is more than 90% with the RSD is not more than 1.24.Compared with other extraction methods e.g. reflux extraction and soaked by organic solvent, better extraction rate was observed for the microwave extraction. The proposed extraction method was applied to extract eucalytus from different places (Guangzhou, Guangxi, Zhaoqing, Yunnan). The results showed that organic acid contents in eucalytus from Zhaoqing were the highest among them.
采用微波辅助提取来提取桉叶中的有机酸。正交设计方法来研究评价萃取溶剂、微波功率和微波时间的效果,并用毛细管电泳来分析萃取样品的提取率。当采用200毫升无水乙醚,在中等微波功率下萃取6分钟,萃取效果最佳,平均回收率超过90%,RSD最大为2.24。与回流提取法和浸提相比,微波辅助萃取有更高的萃取率。采用此方法提取不同产地的桉叶(广州、广西、肇庆、云南)。结果显示肇庆桉叶的有机酸含量是它们当中最高的。
闲鹤野云
原文由 ruojun 发表:
采用微波辅助萃取技术来萃取桉叶中的有机酸。利用正交设计方法来研究萃取技术条件,以期找出最好的萃取溶剂、微波功率和微波照射时间。样品通过毛细管电泳法来分析以计算提取率。当采用200毫升无水乙醚,在中等微波功率下萃取6分钟,萃取效果最佳。此条件下平均回收率超过90%,RSD最大为2.24。与回流提取法和有机溶剂浸提法相比,微波辅助萃取有更高的萃取率。采用此方法提取了不同产地的桉叶(广州、广西、肇庆、云南)。结果显示,肇庆桉叶的有机酸含量是它们当中最高的。
闲鹤野云
其实我检索了一下,这个问题以前提出过
http://www.instrument.com.cn/bbs/shtml/20081214/1639096/
闲鹤野云
还有类似的帖子:http://www.instrument.com.cn/bbs/shtml/20081029/1555498/
happyjyl
微波提取桉树叶中有机酸的工艺研究
摘要:筛选出微波提取桉树叶中有机酸最佳工艺。采用正交设计优化微波提取工艺,对肇庆、广州、广西、云南四种不同产地的桉树叶有机酸进行提取,比较研究了微波提取与常用提取法(回流提取法、浸提法)对有机酸的提取,并用高效毛细管电泳法测定五种有机酸的含量。微波提取五种有机酸的优化工艺:溶剂为无水乙醚,微波功率为中功率,提取时间为4分钟,溶剂用量为300 mL,在此条件下,有机酸的平均回收率大于90%,RSD≤1.24。结果表明,用微波提取法提取肇庆桉树叶五种有机酸具有含量高、省时的特点,值得在中药提取中推广应用。
以上是他以前求助中译英的,不知为何又要倒回来英译中? 原帖见下:
闲鹤野云
原文由 happyjyl 发表:
可能最近此友英语刻苦训练,把有英文的中文的摘要不知如何写了。估计是个硕士生吧,比较不太自信的小家伙。
