主题:【求助】色谱工作站的问题
浏览0 回复4 电梯直达
wild53
不好意思,还得问:方法设置被别人修改了,现在每次在更换不同方法时候总出来一个对话框:off-line method load
You are loading a method file with a configuration which differs from the instrument's current configuration
I intend to be able to run this method on this instrument when I am done editing . Start method resolution to adapt this method to the instrument's current configuration 后面一个按钮resolve method
I intend only to look at the method and perhaps reprocess previouly collected dada. Skip method resolution后面一个按钮 Don't Resolve Method
怎么回事?是不是在GC面板上有人修改设置了如何回复?
还有以前在off-line右下角有一条校准直线,现在没有了,显示 Invalid calibration curve这是怎么回事,如何恢复啊?
c1234567
sea1981
happy水中月
wild53
原文由 lianlxh 发表:
你使用的是什么工作站?
Agilent 6890!
