Degree of substitution— Transfer about 1 g of it, accurately weighed, to a glass-stoppered, 500-mL conical flask, add 300 mL of sodium chloride solution (1 in 10), then add 25.0 mL of 0.1 N sodium hydroxide VS. Inser* the stopper, and allow to stand for 5 minutes with intermittent shaking. Add 5 d-rops of m-cresol purple TS, and from a buret add about 15 mL of 0.1 N hydrochloric acid VS. inser* the stopper in the flask, and shake. If the solution is violet, add 0.1 N hydrochloric acid VS in 1-mL portions until the solution becomes yellow, shaking after each addition. Titrate with 0.1 N sodium hydroxide VS to a violet endpoint. Calculate the net number of milliequivalents, M, of base required for the neutralization of 1 g of Croscarmellose Sodium, on the dried basis.
Calculate the degree of acid carboxymethyl substitution, A, by the formula:
1150M /(7102 – 412M – 80C)
in which C is the percentage of residue on ignition of the Croscarmellose Sodium as determined in the test for Residue on ignition.
Calculate the degree of sodium carboxymethyl substitution, S, by the formula:
(162 + 58A)C/(7102 – 80C).
The degree of substitution is the sum of A + S. It is between 0.60 and 0.85, calculated on the dried basis.
注意:上面的*代替字母T (我把*改成t还真不行,为什么?
![](https://simg.instrument.com.cn/bbs/images/brow/em09512.gif)
取本品1g,精密称定,置于一具有玻璃塞的500mL锥形瓶中,加300mL氯化钠溶液(1:10),25.0mL氢氧化钠滴定液(0.1mol/L)。塞上瓶塞,放置5分钟,时时振摇。加5滴间甲酚紫试液,并用滴定管加约15mL盐酸滴定液(0.1mol/L)。塞上瓶塞,振摇。如果溶液显紫色,可继续加盐酸滴定液(0.1mol/L),每次1mL,直到溶液变成黄色,每加一次均需振摇。然后用氢氧化钠滴定液(0.1mol/L)滴定至紫色为终点。按干品计算中和1g羧甲基纤维素钠干品所需碱的毫克当量M.按下式计算羧甲基酸的取代度A:
1150M /(7102-412M-80C)
式中C是炽灼残渣项下所测得的交联羧甲基纤维素钠残渣百分比
按下式计算羧甲基钠的取代度S:
(162 + 58A)C/(7102-80C)
羧甲基纤维素钠的取代度为A+S.按干品计算,应该在0.60与0.85之间.
