硝酸钯
CAS号: 10102-05-3
英文名称: Palladium nitrate
英文同义词: Palladous nitrate;PALLADIUM (II) NITRATE SOLUTION;PALLADIUM(II) NITRATE;PALLADIUM NITRATE;PALLADIUM STANDARD SOLUTION;Nitricacid,palladium(2+)salt;nitricacid,palladium(2++)salt;palladiumdinitrate;Palladium(II) nitrate dihydrate (Pd ca.40%) (99.9% Pd);Palladium (II) nitrate aq. Soln;PALLADIUM MATRIX MODIFIER, FOR GRAPHITE FURNACE-AAS;PALLADIUM(II) NITRATE, 99.999%, 10 WT. % SOLUTION IN 10 WT. % NITRIC ACID;PALLADIUM(II) NITRATE, 10% SOLUTION 99.999%;PALLADIUM(II) NITRATE, 99.999%;PALLADIUM (II) NITRATE, HYDRATE (PD 40%) (99.9%-PD);PaladiumNitrate;PALLADIUM(II) NITRATE 2 H2O;PALLADIUM NITRATE, SOLUTION;PALLACIUM(II)NITRATE;PALLADIUM (II) NITRATE-2-HYDRATE
中文名称: 硝酸钯
中文同义词: 硝酸亚钯;硝酸钯;二硝酸钯;硝酸钯(2+);硝酸钯,二水;硝酸钯(II)水合物;硝酸钯二水合物;硝酸钯(II)溶液;硝酸钯水合物;硝酸钯(II)溶液, SOLUTION, PD 8.5% W/W (CONT. PD);硝酸钯(II)溶液, SOLUTION, 99.95% (METALS BASIS), PD 12-1;硝酸钯液体;硝酸钯(II);硝酸钯(II)溶液,SOLUTION,99.95%(METALSBASIS),PD12-16%W/W(CONT.PD);硝酸钯(II)二水合物;硝酸钯(II), SOLUTION, PD 4-5% W/W (CONT. PD)
CBNumber: CB0373948
分子式: N2O6Pd
分子量: 230.43
MOL File: 10102-05-3.mol
