1、BBRC (Biochemical and Biophysical Research Communications) Impact Factor: 2.548
从提交到刊出在线版仅用不到3周的时间
Biochemical and Biophysical Research Communications is the premier international journal devoted to the very rapid dissemination of timely and significant experimental results in diverse fields of biological research. The development of the "Breakthroughs and Views" section brings the minireview format to the journal, and issues often contain collections of special interest manuscripts. BBRC is published weekly (52 issues/year).
Research Areas now include: • Biochemistry • Biophysics • Cell Biology • Developmental Biology • Immunology • Molecular Biology • Neurobiology • Plant Biology • Proteomics
