原文由 雾非雾(mcds) 发表:
1. Column efficiency may be specified also as a system suitability requirement, especially if there is only one peak of interest in the chromatogram; however, it is a less reliable means to ensure resolution than direct measurement.
柱效也可以被看作是系统适应性的必要条件,特别是当谱图里只有一个目标峰时,无论如何,确保分辨率比直接测量更重要都是不可靠的。
原文由 雾非雾(mcds) 发表:
