1. Replicate injections of a standard preparation used in the assay or other standard solution are compared to ascertain whether requirements for precision are met.
2. Unless otherwise specified in the individual monograph, data from five replicate injections of the analyte are used to calculate the relative standard deviation, SR, if the requirement is 2.0% or less; data from six replicate injections are used if the relative standard deviation requirement is more than 2.0%.
第一句句型分析: Replicate injections of [(a standard preparation used in the assay) or (other standard solution)] are compared to ascertain whether requirements for precision are met.
含量测试中所使用的标准溶液或其它标准溶液重复进样(的结果)进行比较,以确定精密度要求是否是符合的。
