主题:【每日一句(段)有奖翻译】<二>色谱条件的调整(概述2)
浏览0 回复8 电梯直达
影子
1. Adjustments are permitted only when suitable standards (including Reference Standards) are available
for all compounds used in the suitability test and only when those standards are used to show that the
adjustments have improved the quality of the chromatography in meeting system suitability requirements.
2. Adjustments to chromatographic systems performed in order to comply with system suitability
requirements are not to be made to compensate for column failure or system malfunction.
3. The changes described below may require additional validation data. The user should verify the
suitability of the method under the new conditions by assessing the relevant analytical performance
characteristics potentially affected by the change.
4. Multiple adjustments can have a cumulative effect in the performance of the system and should be
considered carefully before implementation.
dahua1981
多次调整可以在系统性能的累积效应,并应
在实施前认真考虑。
该帖子作者被版主 hyheying3积分, 2经验,加分理由:积极参与
绿洲
1 只有当适用标准(包括参考标准)对适用性检验中的所有化合物均适用,并且证明调整可以改进色谱系统的适用性时,调整才被允许。
myreebok
为达到系统适应性要求调整色谱系统不是为了补偿柱损坏或系统误故障。
以下描述的变更可以需要额外的验证数据。使用者应在新的条件下用评估变更对相关分析性能参数产生的可能地影响来核实方法的的适用性
影子
原文由 dahua1981(dahua1981) 发表:
多次调整可以在系统性能的累积效应,并应
在实施前认真考虑。
可否修改为:
多次调整可能对系统的性能有累积效应,在实施前应仔细考虑。
影子
原文由 avachen(avachen) 发表:
这个翻译个人认为比较恰当,也很通顺
影子
原文由 myreebok(myreebok) 发表:
根据日常习惯,可否作一下小小的调整:
以下描述的变更可需要额外的验证数据。使用者应在新的条件下,通过评估变更对相关分析性能参数产生的可能的影响来确认方法的的适用性
myreebok
poorlittle
Adjustments are permitted only when suitable standards (including Reference Standards) are available for all compounds used in the suitability test and only when those standards are used to show that the adjustments have improved the quality of the chromatography in meeting system suitability requirements.
只有当适用性检验中的所有化合物均有适用之标准(包括参考标准),且该标准能证明通过调整可改善色谱仪之适用性, 方可调整。
