主题:【每日一句(段)有奖翻译】<五>色谱条件的调整(流动相1)
浏览0 回复3 电梯直达
影子
1. Ratio of Components in Mobile Phase (HPLC)— The following adjustment limits apply to minor
components of the mobile phase (specified at 50% or less).
2. The amount(s) of these component(s) can be adjusted by ±30% relative. However, the change in
any component cannot exceed ±10% absolute (i.e., in relation to the total mobile phase).
3. Adjustment can be made to one minor component in a ternary mixture. Examples of adjustments
for binary and ternary mixtures are given below.
该帖子作者被版主 lylsg5553积分, 2经验,加分理由:好活动
绿洲
1 流动相中成分的比例--以下调整限适用于流动相中含量较低的成分(指定为小于等于50%)。
该帖子作者被版主 hyheying3积分, 2经验,加分理由:积极参与
xiaoxiaofly
2 流动相中各组分相对调整的比例可达±30%.但是,任一组分的绝对调整比例(相对于整个流动相)不得超过±10%。
dahua1981
在三元混合物中可以按照一个次要组成部分作出调整。调整为二元和三元混合物举例如下。
