原文由 ainide001(ainide001) 发表:
呵呵,可以明显的看出来,帕纳科的测角仪是齿轮定位的。
还有帕纳科是出名售后服务贵的,楼主惨了啊!
帕纳科的测角仪采用DOPS定位系统
Direct Optical Position Sensing (DOPS)
The DOPS system is used to accurately determine the position of the shaft. The system consists of a
Mettler optical disk(梅特勒光盘), attached to the goniometer drive wheel, and an optical reader. The optical disk is
divided into finely drawn black lines with equally wide white spaces between them
