The interpretation from literal point of view is correct. Are you using the “right procedure”?
I wonder what is the indication (i.e. the display from the equipment) if there is no contaminating leak.
In the other words, “There is no contaminating leak” and “There is contaminating leak” are results of self diagnose. How the user can get these results? Pressing a specific button?
