原文由 sjbsjbsjb(sjbsjbsjb) 发表:
Direct thermal desorption is only appropriate if the desired extraction takes place at a temperature
below the decomposition point of other materials in the sample matrix and provided the relatively
small sample size that can be measured into a thermal desorption tube is representative of the
sample as a whole
