主题:【每日一句(段)有奖翻译】<八十> Terms and Definitions (3)
浏览0 回复2 电梯直达
影子
Alcohol Content
1. Percentages of alcohol, such as those under the heading Alcohol content, refer to percentage by volume of C2H5OH at 15.56 .
2. Where a formula, test, or assay calls for alcohol, ethyl alcohol, or ethanol, the USP monograph article Alcohol shall be used.
3. Where reference is made to “C2H5OH,” absolute (100 percent) ethanol is intended.
4. Where a procedure calls for dehydrated alcohol, alcohol absolute, or anhydrous alcohol, the USP monograph article Dehydrated Alcohol shall be used.
yuminniu
1、酒精浓度,例如在酒精含量标题下,是指在15.56℃时所含C2H5OH的体积分数。
2、在公式、检测和分析实验中所指的酒精或乙醇,使用美国药典中各论酒精所描述的物品。
3、当提到C2H5OH时,毫无疑问是指100%的乙醇。
4、当在过程中使用无水酒精(纯酒精)时,使用美国药典中各论无水酒精所描述的物品。
阿迈
Alcohol Content
酒精含量
1.酒精百分比浓度,如那些在酒精含量标题下的,指的是乙醇在15.56℃时的体积百分比。
