Column | Cogent Diamond Hydride™, 4µm, 100A | ||||||||||||||||||||
Catalog No. | 70000-15P-2 | ||||||||||||||||||||
Dimensions | 2.1 x 150 mm | ||||||||||||||||||||
Solvents | A: DI water + 0.1% ammonium formate B: acetonitrile + 0.1% ammonium formate | ||||||||||||||||||||
Mobile Phase | Gradient:
Flow Rate | 400 µL/min. | ||||||||||||||||||||
Peaks (Compounds) | 1. Maleic acid 115.0031 m/z (M-H)- 2. trans- Aconitic acid 173.0086 m/z (M-H)- 3. Citric acid 191.0192 m/z (M-H)- Sample mixture was prepared in 50% DI water/50% acetonitrile. | ||||||||||||||||||||
Detection | ESI ?neg - Agilent 6210 MSD TOF mass spectrometer |
原文由 kylabs(kylabs) 发表:
我这里有一个分离丁二酸、己二酸、柠檬酸的LCMS条件,你做个参考。
Column Cogent Diamond Hydride™, 4µm, 100A Catalog No. 70000-15P-2 Dimensions 2.1 x 150 mm Solvents A: DI water + 0.1% ammonium formate
B: acetonitrile + 0.1% ammonium formateMobile Phase Gradient:
Time %B Time %B 0.0 90 6.1 30 2.0 90 7.0 30 5.0 70 7.1 30 6.0 70 10.0 90 Flow Rate 400 µL/min. Peaks
(Compounds)1. Maleic acid 115.0031 m/z (M-H)-
Sample mixture was prepared in 50% DI water/50% acetonitrile.Detection ESI ?neg - Agilent 6210 MSD TOF mass spectrometer
