不懂
ICPMS,我来分析下,麦地改错:
It also revealed that relatively small differences in analyte mass can significantly change the local plasma temperature during atomization,
这句里有两个动词:reveal和change,但reveal为被动态且前面没有系动词,因此also revealed that relatively small differences in analyte mass应该是短语,与it同义,作主语,can significantly change 作谓语,the local plasma temperature during atomization作宾语
which would translate in variations in analyte signal, and that the atomization of a major element may negatively affect that of a nearby trace element .
which代表前面整句的意思,that指during atomization
在分析物质量上显示出的较小差异,在雾化期间,可能严重改变局部等离子体的温度,这将转移成分析物信号的改变,且主要元素的雾化可能对附近微量元素产生负面影响
