主题:【每日一句(段)有奖翻译】<九十八> Terms and Definitions (21)
影子
Weights and Measures
1. In general, weights and measures are expressed in the International System of Units (SI) as established and revised by the Conférence générale des poids et mesures.
2. For compendial purposes, the term “weight” is considered to be synonymous with “mass.”
3. Molality is designated by the symbol m preceded by a number that represents the number of moles of the designated solute contained in 1 kilogram of the designated solvent.
dudubringtking
度量衡
1、一般来说,度量衡是由国际单位体系Conférence générale des poids et mesures(法语)制定和修订的。
2、对于药典所称“重量”被认为是等同于“质量。
3、摩尔浓度是指定一个数字,表示1公斤的指定溶剂所含指定溶质的摩尔数的符号。
该帖子作者被版主 hyheying3积分, 2经验,加分理由:积极参与
