还是这篇文章中,我还遇到了一下几个问题:The transmission electron microscopy (TEM) and [0001]
zone-axis high resolution TEM (HRTEM) images taken on the ultrathin section of the microsphere rim (marked in Figure a) (由于不会粘贴图片,请见附件,谢谢!)provide further information on the crystallization. The [0001] zone-axis selected area electron diffraction (SAED) pattern in Figure b discloses that the nanoplatelets grow normal to the [0001] direction.
1.问题:如何从图b看出nanoplatelets 是 平行(normal?)于[0001] 方向的呢?(自我感觉这个问题很弱智,实在是不好意思!拜托)
The results also suggest that there is a narrow range of small angle lattice mismatch between the boundaries of the nanoparticles when assembling in the same orientation.
2.问题:如何通过图a和b,看出纳米颗粒的边界之间存在晶格错配的呢?
The existence of mesopores (or amorphous, defect regions) during the assembly characteristic of the mesocrystal is clearly observed in the HRTEM image (dashed white circles)
3.问题:如何从HRTEM图看出是否存在晶格缺陷呢?
===========版主模式=========
帮你贴了图了
如果需要上传图片,请使用编辑器的
上传功能,图片大小允许最大为:[5MB],允许的格式为:['jpg','gif','jpeg']
