1 ml of this standard solution contains 0,1 µg of Cr(VI).
For the preparation of comparison solution, add 1 ml of phosphoric acid and 1 ml of diphenylcarbazide
solution to 50 ml of standard Cr(VI) solution,
标液中六价铬含量为0.1ug/ml
取50ml显色
Cut a test piece measuring about 50 mm × 50 mm from the coated item and remove any sealing, such as
paint or wax, etc., by scraping the surface.
取试样25cm2,萃取,定容50ml,显色
与标液比较
那么,0.1ug/ml*50ml对应25cm2
不就是0.2ug/cm2
