主题:请问怎么样将chi里面作出来的曲线上不需要的数据去除?
dingdang606
要用chi里面的拟和,但是有些数据影响拟和效果,如何去除,谢谢!
说明书上是这么写的:
Data Point Removing command (DataProc menu)
Use this command to remove unwanted data points of the currently active data. You can only remove data points at the beginning or at the end.
The system displays the Data Point Removing dialog box so you can work on your data.
dingdang606
我已经会了,在导出的数据里删掉,然后再导入就可以了。成功!
