中文名称: 硫酸庆大霉素
中文别名: 庆大霉素硫酸盐; 硫酸艮他霉素; 硫酸正泰霉素; 硫酸双生霉素; 硫酸庆大霉素(细胞培养用)
英文名称: Gentamycin Solution
英文别名: gentamicin solution 10mg/ml sterile*filtered; gentamicin standard solution; gentamicin sulfate from micromonospora purpurea; gentamicin sulfate cell culture tested; gentamicin solution cell culture tested; gentamicin sulfate solution hybri-max*50mg/ml; Gentamicin sulfate, USP Grade; Gentamicin sulfate Micromonospora purpurea; gentamicin sulphate; Gentamycin sulfate; Gentamycin Sulphate; GENTAMICIN 2,5-SULFATE HYDRATE; genoptics.o.p.; gentalline; gentamicinsolution; nsc-82261; sch9724; Gentamicin Sulfate; 4,6-diamino-3-{[3-deoxy-4-C-methyl-3-(methylamino)pentopyranosyl]oxy}-2-hydroxycyclohexyl 2-amino-2,3,4,6,7-pentadeoxy-6-(methylamino)heptopyranoside
CAS号: 1405-41-0
EINECS号: 215-778-9
分子式: C19H41N5O11S
分子量: 547.6207
InChI: InChI=1/C19H39N5O7.H2O4S/c1-19(27)7-28-18(13(26)16(19)24-2)31-15-11(23)5-10(22)14(12(15)25)30-17-9(21)4-3-8(6-20)29-17;1-5(2,3)4/h8-18,24-27H,3-7,20-23H2,1-2H3;(H2,1,2,3,4)/t8-,9+,10-,11+,12-,13+,14+,15-,16+,17+,18+,19-;/m0./s1
分子结构:
熔点: 218-237℃
