欢迎点击 咨询留言>> 我们将在24小时内联系您
货号 | 产品描述 | |
主机 | 1.09751.0001 | Spectroquant® NOVA 60 |
1.09752.0001 | Spectroquant® NOVA 60 A | |
1.00706.0001 | Spectroquant® Pharo 100 | |
1.00707.0001 | Spectroquant® Pharo 300 | |
单参数CRM 标准溶液 | 1.25022.0100 | 氨氮 Ammonium 0.400 mg/l NH4-N in H2O |
1.25023.0100 | 氨氮 Ammonium 1.00 mg/l NH4-N in H2O | |
1.25029.0100 | 化学需氧量 COD 100 mg/l in H2O | |
1.25031.0100 | 化学需氧量 COD 400 mg/l in H2O | |
1.25037.0100 | 硝酸盐 Nitrate 2.50 mg/l NO3-N in H2O | |
1.25038.0100 | 硝酸盐 Nitrate 15.0 mg/l NO3-N in H2O | |
1.25041.0100 | 硝酸盐 Nitrite 0.200 mg/l NO2-N in H2O | |
1.25043.0100 | 总氮 Nitrogen (total) 2.50 mg/l N in H2O | |
1.25044.0100 | 总氮 Nitrogen (total) 12.0 mg/l N in H2O | |
1.25046.0100 | 总磷 Phosphorus (total) 0.400 mg/l PO4-P in H2O | |
1.25047.0100 | 总磷 Phosphorus (total) 4.00 mg/l PO4-P in H2O | |
1.25050.0100 | 硫酸盐 Sulfate 40 mg/l SO4 in H2O | |
1.25051.0100 | 硫酸盐 Sulfate 125 mg/l SO4 in H2O |
货号 | 产品描述 | 用户促销价 | |
单参数CRM 标准溶液 | 1.25022.0100 | 氨氮 Ammonium 0.400 mg/l NH4-N in H2O | 334 |
1.25023.0100 | 氨氮 Ammonium 1.00 mg/l NH4-N in H2O | 334 | |
1.25029.0100 | 化学需氧量 COD 100 mg/l in H2O | 334 | |
1.25031.0100 | 化学需氧量 COD 400 mg/l in H2O | 334 | |
1.25037.0100 | 硝酸盐 Nitrate 2.50 mg/l NO3-N in H2O | 334 | |
1.25038.0100 | 硝酸盐 Nitrate 15.0 mg/l NO3-N in H2O | 334 | |
1.25041.0100 | 硝酸盐 Nitrite 0.200 mg/l NO2-N in H2O | 334 | |
1.25043.0100 | 总氮 Nitrogen (total) 2.50 mg/l N in H2O | 334 | |
1.25044.0100 | 总氮 Nitrogen (total) 12.0 mg/l N in H2O | 334 | |
1.25046.0100 | 总磷 Phosphorus (total) 0.400 mg/l PO4-P in H2O | 334 | |
1.25047.0100 | 总磷 Phosphorus (total) 4.00 mg/l PO4-P in H2O | 334 | |
1.25050.0100 | 硫酸盐 Sulfate 40 mg/l SO4 in H2O | 334 | |
1.25051.0100 | 硫酸盐 Sulfate 125 mg/l SO4 in H2O | 334 | |
CombiCheck混合标准溶液 | 1.14676.0001 | Spectroquant® CombiCheck 10 | 818 |
1.14675.0001 | Spectroquant® CombiCheck 20 | 826 | |
1.14677.0001 | Spectroquant® CombiCheck 30 | 911 | |
1.14692.0001 | Spectroquant® CombiCheck 40 | 897 | |
1.14695.0001 | Spectroquant® CombiCheck 50 | 882 | |
1.14696.0001 | Spectroquant® CombiCheck 60 | 983 | |
1.14689.0001 | Spectroquant® CombiCheck 70 | 890 | |
1.14738.0001 | Spectroquant® CombiCheck 80 | 983 | |
PhotoCheck | 1.14693.0001 | PhotoCheck 波长检测系统 | 2887 |
PipeCheck | 1.14962.0001 | PipeCheck 移液器准确性检测系统 | 2949 |
原文由 dongdong94(gat) 发表:可以的,这些标准溶液可以作为验证溶液或绘制标准曲线,这些标液可以直接溯源至NIST一级标准,提供详细的分析质量证书奥!具体的可以与我们取得联系,这些试剂目前这个月还有促销,每瓶都是100ML装的,3年的保质期。
我们这儿还有国产光度计在用,不知能不能用这些标准溶液做验证或者做标准曲线?
看似浓度值比国产品种多,应该不用稀释了吧。
标准溶液订购信息,(CRM),100ml水溶液 | |||
产品 | 浓度 | 扩展不确定度 | 货号 |
A Ammonium 氨氮 | 0.400 mg/l NH4-N | ± 0.012 mg/l | 1.25022.0100 |
Ammonium 氨氮 | 1.00 mg/l NH4-N | ± 0.04 mg/l | 1.25023.0100 |
Ammonium 氨氮 | 2.00 mg/l NH4-N | ± 0.07 mg/l | 1.25024.0100 |
Ammonium 氨氮 | 6.00 mg/l NH4-N | ± 0.13 mg/l | 1.25025.0100 |
Ammonium 氨氮 | 12.00 mg/l NH4-N | ± 0.4 mg/l | 1.25026.0100 |
Ammonium 氨氮 | 50.0 mg/l NH4-N | ± 1.2 mg/l | 1.25027.0100 |
C COD 化学需氧量 | 20.0 mg/l | ± 0.7 mg/l | 1.25028.0100 |
COD 化学需氧量 | 100 mg/l | ± 3 mg/l | 1.25029.0100 |
COD化学需氧量 | 200 mg/l | ± 4 mg/l | 1.25030.0100 |
COD化学需氧量 | 400 mg/l | ± 5 mg/l | 1.25031.0100 |
COD化学需氧量 | 1,000 mg/l | ± 11 mg/l | 1.25032.0100 |
COD化学需氧量 | 2,000 mg/l | ± 32 mg/l | 1.25033.0100 |
COD化学需氧量 | 8,000 mg/l | ± 68 mg/l | 1.25034.0100 |
COD化学需氧量 | 50,000 mg/l | ± 894 mg/l | 1.25035.0100 |
N Nitrate 硝酸盐 | 0.50 mg/l NO3-N | ± 0.05 mg/l | 1.25036.0100 |
Nitrate 硝酸盐 | 2.50 mg/l NO3-N | ± 0.06 mg/l | 1.25037.0100 |
Nitrate 硝酸盐 | 15.0 mg/l NO3-N | ± 0.4 mg/l | 1.25038.0100 |
Nitrate 硝酸盐 | 40.0 mg/l NO3-N | ± 1 mg/l | 1.25039.0100 |
Nitrate 硝酸盐 | 200 mg/l NO3-N | ± 5 mg/l | 1.25040.0100 |
Nitrite 亚硝酸盐 | 0.200 mg/l | ± 0.009 mg/l | 1.25041.0100 |
Nitrite 亚硝酸盐 | 40.0 mg/l NO2-N | ± 1.3 mg/l | 1.25042.0100 |
Nitrogen (total)总氮 | 2.50 mg/l N | ± 0.06 mg/l | 1.25043.0100 |
Nitrogen (total)总氮 | 12.0 mg/l N | ± 0.3 mg/l | 1.25044.0100 |
Nitrogen (total)总氮 | 100 mg/l N | ± 3 mg/l | 1.25045.0100 |
P Phosphorus (total)总磷 | 0.400 mg/l PO4-P | ± 0.016 mg/l | 1.25046.0100 |
Phosphorus (total)总磷 | 4.00 mg/l PO4-P | ± 0.08 mg/l | 1.25047.0100 |
Phosphorus (total)总磷 | 15.0 mg/l PO4-P | ± 0.4 mg/l | 1.25048.0100 |
S Sulfate硫酸盐 | 40 mg/l SO4 | ± 6 mg/l | 1.25050.0100 |
Sulfate硫酸盐 | 125 mg/l SO4 | ± 6 mg/l | 1.25051.0100 |
Sulfate硫酸盐 | 400 mg/l SO4 | ± 20 mg/l | 1.25052.0100 |
Sulfate硫酸盐 | 800 mg/l SO4 | ± 27 mg/l | 1.25053.0100 |
