对于不易溶解的细胞因子或蛋白,PeproTech会在说明书中进行备注(Note)。如在重组人IL-13(产品编号:200-13)的说明书中您会看到:Slow to dissolve (缓慢溶解),在重组人IL-11(产品编号:200-11)的说明中会看到: This solution is slow to dissolve.(该溶液溶解缓慢)。这种情况下,您最好能将要溶解的细胞因子或重组蛋白放在水平摇床(shaker)上低速摇一段时间,促使细胞因子或重组蛋白完全溶解。
有些蛋白,如重组人IL-13 Variant (产品编号:200-13A)虽然难溶,但却不需用摇床来加速溶解。其说明书上的备注为:Allow the reconstituted vial to sit at 4℃for at > 2 hours before use. (将重悬液在4℃静置2小时以上)
3. This solution can be stored at 2-8℃ for up to 1 week.
4. For extended storage, it is recommended to further dilute in a buffer containing a carrier protein (example 0.1% BSA) and store in working aliquots at -20℃to -80℃.
