136.3 HPLC法测定独一味中类叶升麻苷
【作者】 刘婕; 许浚; 张铁军;
【Author】 Liu Jie1,Xu Jun2,Zhang Tie-jun2(1.Department of Graduate Student,Tianjin University of Chinese Medicine,Tianjin 300193,China;2.Tianjin Institute of Pharmaceutical Research,Department of Traditional Medicine Modern Research,Tianjin 300193,China)
【机构】 天津中医药大学研究生部; 天津药物研究院现代中药研究部;
【摘要】 目的建立藏药独一味中类叶升麻苷的测定方法。方法采用HPLC法。色谱条件:Diamonsil C18色谱柱(200mm×4.6mm,5μm);以乙腈-甲醇-1%醋酸水溶液(10:15:75)为流动相;体积流量为1.0mL/min;柱温35℃;检测波长334nm。结果类叶升麻苷在0.2272~1.3632μg呈良好的线性关系,r=0.9992,加样回收率、精密度、稳定性和重现性试验结果均符合要求。结论该方法专属性强、灵敏度高、精确度与重现性好,适用于独一味中类叶升麻苷的测定。 更多还原
【Abstract】 Objective To establish the method for determination of acteoside in Lamiophlomis rotata(Benth.) Kudo.Methods Acteoside was determined by the HPLC with Diamonsil C18 column,the mobile phase consiste of acetonitrile-methanol-1% acetic acid(10:15:75),flow rate of 1.0 mL/min,UV detection wavelength of 334 nm,and column temperature of 35 ℃.Results This method was linear over ranges of 0.227 2~1.363 2 μg(r=0.999 2) for acteoside.The results of tests for the average recovery,precision,stability,and rep... 更多还原
【关键词】 独一味; 类叶升麻苷; HPLC法;
【Key words】 Lamiophlomis rotata(Benth.) Kudo; acteoside; HPLC;
【基金】 “十一五”国家科技支撑计划(2006BAI06A01-02,NO.2007BAI41B06)
