134.4 三七超微粉与细粉中三七皂苷R1及人参皂苷Rg1、Rb1的含量比较研究
【作者】 邓雯; 夏荃; 詹若挺; 成金乐; 许晓峰;
【Author】 DENG Wen1,XIA Quan2,ZHAN Ruo-ting1,CHENG Jin-le3,XU Xiao-feng2(1.Research Center of Chinese Medicinal Resource Science and Engineering of Gangzhou University of TCM,Guangzhou 510006,China;2.School of Pharmaceutical Sciences of Gangzhou University of TCM,Guangzhou 510006,China;3.Zhongzhi Chinese Medicine Co.,Ltd.Zhongshan 528400,China)
【机构】 广州中医药大学中药资源科学与工程研究中心; 广州中医药大学中药学院; 广东中山中智药业集团; 广州中医药大学中药学院 广东广州510006; 广东广州510006; 广东中山528400;
【摘要】 目的测定三七超微粉中三七皂苷R1及人参皂苷Rg1、Rb1的含量,为三七超微粉质量评价提供依据。方法采用高效
液相法,Diamonsil C18柱(250 mm×4.6 mm,5μm),流动相为乙腈-水二元梯度洗脱;流速:1 mL.min-1;检测波长:203 nm;柱温:25℃。结果三七超微粉中三七皂苷R1、人参皂苷Rg1和人参皂苷Rb1的平均含量均高于三七细粉,两者间的含量有显著性差异。结论超微粉质量优于细粉。本实验的含量测定方法简便、准确,可为三七超微粉的质量控制提供一定的参考依据。 更多还原
【Abstract】 Objective To determine the contents of notoginsenoside R1 and ginsenoside Rg1 and Rb1 of micronized powder and fine powder of Panax notoginseng.Methods Diamonsil C18(250 mm×4.6 mm,5 μm) column was used with gradient elution.,and the mobile phase consisted of acetonitrile and water by binary gradient elution.The flow rate was 1 mL· min-1.The detective wavelength was set at 203nm and column temperature was 25℃.Results There was significant difference of 3 components between fine powder and microni... 更多还原
【关键词】 三七超微粉; 细粉; 三七皂苷R1; 人参皂苷Rg1; 人参皂苷Rb1;
【Key words】 micronized powder of Panax notoginseng; fine powder of Panax notoginseng; notoginsenoside R1; ginsenoside Rg1; ginsenoside Rb1;
