主题:【求助】定性求助以及其它
浏览0 回复17 电梯直达
everlastingz
悬赏金额:25积分 状态: 已解决
  自己进样CASSIFIX(IFF)加仑子醇的原料,33.131 ,34.649,34.737,35.226,35.859 ,35.999,36.213 ,36.604,36.879 ,37.456这些峰不知全部是主要组分还是其中一些是杂质(异构体),请大家帮助逐个确定下!再次感谢大家!
推荐答案:symmacros回复于2013/05/02
A study was conducted to determine some physico-chemical properties of the test material. The freezing point was less than -25 C according to EEC Method A1. The boiling point/boiling range was 301.5 to 309.5 C at 1010 mbar according to EEC Method A2. The relative density (D420) was 0.98591 according to EEC Method A3. The vapour pressure was 1.5 Pa at 25 C according to EEC Method A4. The surface tension was 54.7 mN/m for a 90% saturated aqueous solution at 19.5 C according to EEC Method A5. The water solubility was 1.1 x 10(-2) g/l at 20 C according to EEC Method A6. The partition coefficient was Log P >3.66 at 21 C according to EEC Method A8. The flash point was 144.5 C according to EEC Method A9. The flammability (in contact with water ) was not flammable under the test conditions according to EEC Method A12. The pyrophoric properties of liquids and solids according to EEC Method A13 = not pyrophoric under test conditions. The explosive properties according to EEC Method A14 = no explosive under test conditions. Autoignition temperature (liquids and gases) was 240 C according to EEC Method A15.
补充答案:
牛二回复于2013/05/03
1111111111111
牛二回复于2013/05/03
我看了 我的样品和楼主的一样
symmacros
everlastingz
原文由 symmacros(jimzhu) 发表:
能否存在网盘或QQ上传,从仪器网下载太难。
是啊,论坛还在抽,我打开帖子都要刷半天,已经上传网盘了,链接是
http://pan.baidu.com/share/link?shareid=171181&uk=1543870179
http://pan.baidu.com/share/link?shareid=171182&uk=1543870179
symmacros
everlastingz
30.496可能和Hedione有关。
感谢朱老师,加仑子醇那个还麻烦朱老师帮看一下
everlastingz
everlastingz
symmacros
CASSIFIX(1-Methyl-4-(1,2,2-trimethylbicyclo[3,1,0]hex-3-yl)-2-oxabicyclo[2,2,2]octane)是沸点范围较宽的原料,或者讲不是一个单峰,相关的资料较少,许多是unpublished。
symmacros
symmacros
SPECIFICATIONS
APPEARANCE AT 20°C CLEAR MOBILE LIQUID
COLOR COLORLESS TO PALE YELLOW
ODOR FRESH, HERBAL, FRUITY, CASSIS
TASTE
DENSITY AT 20°C (g/ml) 0,980 - 0,988
REFRACTIVE INDEX nD20 1,4990 - 1,5040
OPTICAL ROTATION (°) 0 / 0
FLASHPOINT (°C) 101
SOLUBILITY SOLUBILITY IN WATER: NON DETERMINED
ASSAY (% GC)  PEAK 1+2:20-35;PEAK 3:20-38;PEAK 4:5-16;SUM SEC>98
ACID VALUE (mg KOH/g) -
everlastingz
感谢朱老师提供的资料,这个原料是公开没有多久吗
