原文由 chemistryren(chemistryren) 发表:
你确定EPA上的是滤纸吗?不是翻译错了吧?
2540 D. Total Suspended Solids Dried at 103–105°C
1. General Discussion
a. Principle: A well-mixed sample is filtered through a weighed standard glass-fiber filter
and the residue retained on the filter is dried to a constant weight at 103 to 105°C. The increase
in weight of the filter represents the total suspended solids. If the suspended material clogs the
filter and prolongs filtration, it may be necessary to increase the diameter of the filter or decrease
the sample volume. To obtain an estimate of total suspended solids, calculate the difference
between total dissolved solids and total solids.
应该是 玻璃微纤维滤纸
