原文由 依风1986(xurunjiao5339) 发表:原文由 littalnala(littalnala) 发表:原文由 依风1986(xurunjiao5339) 发表:原文由 littalnala(littalnala) 发表:原文由 依风1986(xurunjiao5339) 发表:
以质控图做对,比如对应固定浓度的某元素强度变化,2SD 3SD,平均值等参数变化一个变化范围更合理,个人意见
请问质控图怎么来做呢?我这边从没做过QC质控对比,是否需要买那些元素的质控样来做呢?
质控图在这些行业用的比较广,楼主可以在此论坛资料下载一些看一看!不需要买哪些元素,直接是你用的工作曲线某浓度下元素!
你能帮忙提供一下做质控图的相关资料么?或者能直接分享下用工作曲线某个浓度点怎么来做质控吗?万分感谢!
2.5.3 Daily Performance Check
日常运作核查
The daily performance of the ICP machine shall be monitored by measuring the
intensity value of the control point standard solution and evaluating any trending per
the charting procedures stated below:
ICP日常操作应该被监控通过测量控制点标准溶液的发射强度值和评价下面提到的趋势
图程序:
2.5.3.1 The Intensity Trend Chart is obtained by plotting the intensity value against
the run number on a line graph. The intensity values shown below were
derived from 1.0 ppm standards in 5% nitric acid. Choose a concentration
value that is used in the calibration procedure (i.e. 1, 5 or 10 ppm) when
creating the Trend Chart. 20 different readings will be recorded and graphed
(see Figure 1).
强度趋势图通过绘制强度值与一根直线制对比得到。强度值显示是从1.0ppm的
5%硝酸的Mn标准溶液得出。当创建趋势图时选择一个浓度值用于校准程序(例
如:1,5或10ppm)。记录20个读数并作图(见图1)。
[img=,556,228]file:///C:/DOCUME~1/XUEIRU~1/LOCALS~1/Temp/ksohtml/wps_clip_image-6393.png[/img]
1ppm pb ICP 強度趨勢控制圖列子
x is the intensity value of the control point standard solution (1ppm
standard solution of each element),
x是控制点标准溶液的强度值(1ppm的每个元素的标准溶液)。
xm is the mean intensity value of the control point standard solution which is
collected 20 times on different days.
Xm的是控制点标准溶液的平均强度值,是在不同的天收集到的20次数据。
SD is the standard deviation of 20 measurements.
SD是20次测量值的标准偏差。
UCL is upper control limit, UCL=xm + 3SD, LCL is lower control limit,
LCL=xm-3SD, UWL is upper warning limit, UWL=xm+2SD, LWL is lower warning limit,LWL= xm-2SD.
UCL是控制上线,UCL=xm + 3SD,LCL是控制下线,LCL=xm-3SD, UWL是警
戒上线,UWL=xm+2SD,LWL是警戒下线,LWL= xm-2SD。
2.5.3.2 Daily ICP intensity for each element should be tested and reported on the ICP
daily intensity chart. An example of the ICP intensity chart is attached in
Appendix 1. Intensity trend chart should be renewed every 6 months.
每个元素的ICP强度每天需要测试和记录在ICP日常强度图上。ICP强度图的一
个例子附于附件1。强度趋势图需要每6个月更新一次。•Prepare new control standard solution (1ppm standard solution of each
element)
原文由 littalnala(littalnala) 发表:原文由 依风1986(xurunjiao5339) 发表:原文由 littalnala(littalnala) 发表:原文由 依风1986(xurunjiao5339) 发表:原文由 littalnala(littalnala) 发表:原文由 依风1986(xurunjiao5339) 发表:
日常运作核查
图程序:
(see Figure 1).
SD是20次测量值的标准偏差。
element)
你发过来的图看不到耶,不过具体意思是:读出该浓度点的平均吸光值,求出SD,范围是Xm+-3SD,对吗?谢谢!
原文由 littalnala(littalnala) 发表:原文由 尘(fjh26) 发表:原文由 littalnala(littalnala) 发表:原文由 尘(fjh26) 发表:原文由 littalnala(littalnala) 发表:原文由 尘(fjh26) 发表:原文由 littalnala(littalnala) 发表:原文由 尘(fjh26) 发表:
只拿曲线吸光值比较很不合理
一般上机后看标线的R值,如果高于0.995就接受了此标线。
要拿标准样品确认才是最合理的,线性好不能代表曲线是合格的,样品值是对的
哦,你做过类似的试验实验吗?就是那标准样来验证标液的有效期
对于检测行业来说,质控才是最重要的
就是怎么来做质控咯,有没相应的操作方法介绍下呢?今天上午在论坛上下载的那个”怎么看质控图“的资料,是打不开的
质控图我也没研究过,买的都是国家标准样品,有浓度范围的
可以把相关的浓度范围提供一下吗?谢谢!
原文由 littalnala(littalnala) 发表:原文由 andrew-zhang(andrew-zhang) 发表:原文由 littalnala(littalnala) 发表:原文由 秋月芙蓉(ljhciq) 发表:
能用标准物质做质控是最好的,实际工作中这样做工作量比较大
现代的仪器配标实现了自动进样,以致配一个高浓度点即可
请问标准物质做质控具体怎么来做呢?另外去哪买这种标准物质,能否提供下相关信息,谢谢!
最好还在质控图,我们是做均值-3S图
请问你们是怎么做的呢?能把方法分享一下吗?另外”均值-3S图“又是代表什么,谢谢!
原文由 littalnala(littalnala) 发表:对,这种就是原文由 秋月芙蓉(ljhciq) 发表:原文由 littalnala(littalnala) 发表:标物中心有出售,液体、固体的都有,一般以基质相同为好原文由 秋月芙蓉(ljhciq) 发表:
GSB07-1183-2000 水质 铅(标样) 20ml玻璃安瓿 这种是吗?
原文由 秋月芙蓉(ljhciq) 发表:原文由 littalnala(littalnala) 发表:对,这种就是原文由 秋月芙蓉(ljhciq) 发表:原文由 littalnala(littalnala) 发表:标物中心有出售,液体、固体的都有,一般以基质相同为好原文由 秋月芙蓉(ljhciq) 发表:
原文由 littalnala(littalnala) 发表:将已经浓度稀释至你的曲线线性范围,当样品测定原文由 秋月芙蓉(ljhciq) 发表:原文由 littalnala(littalnala) 发表:对,这种就是原文由 秋月芙蓉(ljhciq) 发表:原文由 littalnala(littalnala) 发表:标物中心有出售,液体、固体的都有,一般以基质相同为好原文由 秋月芙蓉(ljhciq) 发表:
请问具体怎么操作呢?能详解一下么,谢谢!
