主题:【求助】丙森锌用什么溶解?
浏览0 回复16 电梯直达
q38677504
RT,大家有做过丙森锌的吗?用什么定容的?我试过丙酮定容但是不溶解,标准品不是很多,不敢再试其他的了。。。
该帖子作者被版主 MMYG2积分, 2经验,加分理由:讨论
雾非雾
丙森锌不溶于大部分有机溶剂,水中0.01g/L,一般都是把它酸解面二硫化碳再测。
q38677504
原文由 雾非雾(mcds) 发表:
请问有没有什么标准或是检测方法?我查了下没有查到。。。
q38677504
估计能溶于N,N二甲基酰胺、四氢呋喃建议加热试试
请问您做过这类的吗?有没有标准或是检测方法?
q38677504
没做过,是在百度上查的,你在百度上查查。
正因为我在百度上看过这句话,所以才问你是不是自己做过了,因为我的标准品不是很多,不敢再去验证了。
西北风
还是根据检测方法来确定标准物质溶解方法,用水溶解也是一个选择,试试用甲醇溶解如何
雾非雾
40 Pesticides out of a multi-target screening method for 300 compounds
色谱柱:Synergi™ 4 µm Fusion-RP 80 Å, $$lc Column 50 x 2 mm, Ea
货号:00B-4424-B0
尺寸:50 x 2 mm ID
洗脱类型:Gradient
洗脱A:H2O + 5mM NH4formate
洗脱B:CH3OH + 5mM NH4formate
梯度:
步骤顺序时间 ()洗脱A洗脱B
108020
2111090
3231090
流速:0.2 mL/min
冷却温度:20 °C
检测:Mass Spectrometer (MS) @ amu (22°C)
Detector Info:AB Sciex 4000 QTRAP® $$lc/MS/MS system, Turbo V, source with TurboIonSpray® probe
TEM = 450°C, IS= 5000V, Declustering Potential (DP) = 30V, Collision Energy (CE) = optimized for each compound
Positive polarity, Multiple Reaction Monitoring of 297 transitions (MRMs of example see table)
Information Dependent Acquisition of 3 Enhanced Product Ion spectra to confirm detected compound at CE = 20, 35, and 50V, Dynamic fill time to avoid linear ion trap saturation, Dynamic background subtraction to allow detection of co-eluting peaks, Mass spectral library searching
备注:SecurityGuard™ Guard Cartridge System extends column lifetime.
- SecurityGuard Cartridges, Fusion-RP 4 x 2.0mm, 10/Pk Part No.: AJ0-7556
- Holder Part No.: KJ0-4282
Screening of 535 Pesticides by QuEchERS and $$lc/MS/MS
色谱柱:Synergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea
货号:00B-4423-B0
尺寸:50 x 2 mm ID
洗脱类型:Gradient
洗脱A:Water/Methanol (90:10) + 5 mM ammonium formate
洗脱B:Methanol/Water (90:10) + 5 mM ammonium formate
梯度:
步骤顺序时间 ()洗脱A洗脱B
101000
211000
3150100
4180100
518.051000
6201000
流速:0.4 mL/min
冷却温度:40 °C
检测:Tandem Mass Spec (MS-MS) @ (400°C)
Detector Info:AB Sciex API 3200™
备注:Phenomenex SecurityGuard Guard Cartridge kit (P/N KJ0-4282) with C18 4 x 2.0 mm cartridge (P/N AJ0-4286)
2013/7/2 10:46:47 Last edit by mcds
荆棘鸟
楼主可以参考一下这篇文献:中性氧化铝柱净化—高效液相色谱法测定菠菜中的代森锰锌丙森锌和福美双
http://www.cnki.com.cn/Article/CJFDTotal-NCJX201204042.htm
这个分析方法应该是有标品如何配制的。
我下不下来,哪位给帮一下忙。
xiaolanzi5
该帖子作者被版主 mcds2积分, 2经验,加分理由:分享
