主题:如何用MALDI-TOF-MS进行蛋白样品预处理?
浏览0 回复15 电梯直达
biolxm
我前几天才用MALDI-TOF-MS分析蛋白质,虽然我按照别人给我的方法进行蛋白样品处理,但我不知道为什么要用乙腈和碘乙酰胺,而且整个过程也看得不是很明白。那位大哥能告诉我样品处理的详细过程以及它使用的原理吗?谢谢!(我用胰酶切的)。
您可能想找: 生物质谱/MALDI-TOF 询底价
Esquire
推荐你一个网址:
http://www.proteomics.com.cn/
是军事医学科学院国家生物医学分析中心的网址
里面有一个论坛,对你会有很多帮助。
zzwbj
Cylindrical gel samples of 1-mmdiameter were excised and destained by incubation with 400 uL
of 25% 2-propanol for 30 min. The destained gel samples were
dried in a Speedvac for 10 min, followed by addition of 5 uL of
digestion buffer (5 mM DTT, 5 mM n-octyl glucopyranoside (n-
OGP), 20 mM Tris, pH 7.8) containing 12 ng/ÌL modified porcine
trypsin (sequencing grade, Promega). After overnight incubation
at 37 °C, 5 ÌL of 0.4% TFA, 5 mM n-OGP was added and the
incubation was extended for 1 h at room temperature. To obtain
sufficient volume for comparison of sample preparation methods,
an additional 5 ÌL of 0.2% TFA, 5 mM n-OGP was added. Samples
were stored at -20 °C prior to MALDI sample preparation.
biolxm
谢谢!
gfzhang
zzwbj
北医有一台岛津公司的tof仪器,另外,北大生物系也有一台,有什么需要帮忙的吗?
我又来也
gfzhang
gop
新推出的蛋白质分析质谱仪,分析最大质量达到10MDa,技术参数可浏览公司网页:http://www.comet.ch/index.php?id=21
zzwbj
gfzhang
