现将VIM3涉及不确定度与真值关系的条款(这些条款2012版与2008版相同),复印如下,不是打字,而是复印,保证不错一个符号。令人惊讶的是,在《JJF1001-2011》中居然回避“真值”二字,把“真值”改为“量值”。此事发生在信仰辩证唯物论的国度里,岂非咄咄怪事。要注意,VIM2008版问世三年后,JJF竟然如此,这就不全是迷信洋人的问题了。我们不禁要说:做为《JJF1001-2011》主要起草人的第一人的叶德培先生,国际规范都不得不承认的真值,你(们)竟敢抹掉,太放肆了!-
2.26 (3.9) measurement uncertainty
non-negative parameter characterizing the dispersion of the quantity values being attributed to a measurand, based on the information used
NOTE 1 Measurement uncertainty includes components arising from systematic effects, such as components associated with corrections and the assigned quantity
values of measurement standards, as well as the definitional uncertainty. Sometimes estimated systematic effects are not corrected for but, instead, associated measurement uncertainty components are incorporated.
NOTE 2 The parameter may be, for example, a standard deviation called standard measurement uncertainty (or a specified multiple of it), or the half-width of an interval, having a stated coverage probability.-
2.36 coverage interval
interval containing the set of true quantity values of a measurand with a stated probability, based on the information available
NOTE 1 A coverage interval does not need to be centred on the chosen measured quantity value (see JCGM 101:2008).
NOTE 2 A coverage interval should not be termed “confidence interval” to avoid confusion with the statistical concept (see GUM:1995, 6.2.2).
NOTE 3 A coverage interval can be derived from an expanded measurement uncertainty (see GUM:1995, 2.3.5).-
2.37 coverage probability
probabilitythat the set of true quantity values of a measurand is contained within a specified coverage interval
NOTE 1 This definition pertains to the Uncertainty Approach as presented in the GUM. NOTE 2 The coverage probability is also termed “level of confidence” in the GUM.
原文由 刘彦刚(pxsjlslyg) 发表:
它山之石——史锦顺 :
回复 6# 刘彦刚 -2.26 (3.9) measurement uncertainty
2.26(3.9)测量不确定度
用来描述被测对象的量值分散现象的非负参数是建立在以下2点上的。
NOTE 1 Measurement uncertainty includes components arising from systematic effects, such as components associated with corrections and the assigned quantity values of measurement standards, as well as the definitional uncertainty. Sometimes estimated systematic effects are not corrected for but, instead, associated measurement uncertainty components are incorporated.
1. 测量不确定度包括由系统影响引起的分量,如与修正量和测量标准所赋量值有关的分量及定义的不确定度。有时对估计的系统影响未作修正,而是当作不确定度分量处理
2. 此参数可以是诸如称为标准测量不确定度的标准偏差(或其特定倍数),或是说明了包含概率的区间半宽度。
以上两条我在网上找到了原翻译,http://www.labdd.com/a/yixuejianyan/shenghuajianyan/3095_3.html)
2.36 覆盖区间
包含区间是以特定概率包含真值组的区间,以现有信息为基础的。
(http://bbs.instrument.com.cn/shtml/20131118/5064994/)
包含区间不必以测量量值为中心(可参考JCGM 101:2008)
包含区间不应该被定义为“置信区间”,避免与统计学概念弄混淆(可参考GUM:1995,6.2.2)
包含区间可以从测量扩展不确定度衍生而来(可参考GUM:1995,2.3.5)
2.37 范围概率/包含概率?(没把握)
一组被测量对象的真数值的概率包含在一个特定包含区间内
有关不确定度方法的定义在GUM能找到。
在GUM里,包含概率也被看做“置信水平”
原文由 西瓜猫猫西瓜(vivi_vivi) 发表:
很多计量术语不咋了解 翻译起来有点不准
原文由 刘彦刚(pxsjlslyg) 发表:原文由 西瓜猫猫西瓜(vivi_vivi) 发表:
很多计量术语不咋了解 翻译起来有点不准
虽说有些不准,但是,对于我要解决的问题这样就足够了!因为已经让我得知11楼之
它山之石——史锦顺 :
回复 6# 刘彦刚 -
之说不太靠谱了!还去说什么:
实在不应该!你说呢!
它山之石——史锦顺 :
回复 6# 刘彦刚 -现将VIM3涉及不确定度与真值关系的条款(这些条款2012版与2008版相同),复印如下,不是打字,而是复印,保证不错一个符号。令人惊讶的是,在《JJF1001-2011》中居然回避“真值”二字,把“真值”改为“量值”。此事发生在信仰辩证唯物论的国度里,岂非咄咄怪事。要注意,VIM2008版问世三年后,JJF竟然如此,这就不全是迷信洋人的问题了。我们不禁要说:做为《JJF1001-2011》主要起草人的第一人的叶德培先生,国际规范都不得不承认的真值,你(们)竟敢抹掉,太放肆了!-
先生把我的意见理解反了。
我的意思是说,GUM的不确定度,说不确定度与真值无关,叶先生现在写文章仍然说不确定度与真值无关,是纯粹的不确定度论。
但叶先生是不识时务,当今的不确定度的标准解释应该是VIM3的2008版与2012版的解释。不确定度是包含真值的区间的半宽。把我上传的几段英文的大字部分连起来,就是:不确定度是包含区间的半宽,此区间以一定概率包含真值。
但是,叶德培先生起草(第一起草人)的JJF1001-2011,明明是翻译(当然是翻译VIM2008版,不可能翻译2012版),却把原文的“真值”改成量值,这是很错误的。外国人都已认识到不能离开真值,而中国的JJF却回避真值,这可是哲学思想上出了问题。
把三段英文的讲真值,和JJF1001-2011的相应条文(5.18注2、5.28、5.29)对比一下,就可看出问题。
例如 VIM3 的讲究真值的写法为:
而JJF1001-2011 的条款是:
5.28 包含区间【VIM2.36】
基于可获得的信息确定的包含被测量一组值的区间,被测量值以一定概率落在该区间内。
英文原文是被测量的真值组,中文却改为被测量一组值。这是明目张胆的篡改!明明注着此条等效于VIM2.36 ,而原文有“真值”,中文规范却回避了。
