To avoid confusion, it should be noted that different adsorption methods are named solid-phase extraction【6】. First ofall, these are techniques based on the use of chemically bonded complexing groupings【10】. Commercially available Kelex-100,containing iminodiacetate functions is one of best known adsorbents of this kind.【7,8】 A number of adsorption materials with various classical chelating groups as well as with macrocycles attached to silica gel by a chemical bond are applied.【9,10】 There are some new technologies that have appeared in SPE and SPE-related products. Solid-phase microextraction (SPME) involves the sorption of analytes onto a microfiber, which is made of a fused-silica fiber coated with a hydrophobic polymer. SPME is usually followed by direct desorption in the inlet of a gas chromatograph.【11,12】 This method can be considered as a microvariant of extraction chromatography【13】 There are some new phases for SPE including highly cross-linked copolymers, graphitized carbon for adsorbing polar organic compounds, internal reversed-phase sorbents for clean-up of complex biological materials, etc.【6】
为了避免混淆,应当注意到有几种不同的吸附方法均命名为固相萃取。首先,这些技术都基于化学键合配位基团的应用。商业产品Kelex-100含有亚氨基双乙酸酯官能团,是最为知名的这种类型的吸附剂之一。目前使用的很多吸附材料中具有各种经典配位基团或大环结构与硅胶化学键合。在SPE及其相关产品中出现了一些新技术。固相微萃取(SPME)技术将待分析物吸附在微纤维上,此微纤维由熔融二氧化硅制成并涂覆了疏水性聚合物。SPME通常随后在
气相色谱的入口进行直接解吸。这种方法可以被看作是萃取色谱的微型变体。有几种新的固定相可用于SPE,包括高度交联的共聚物、石墨化的碳用于吸附极性有机化合物、内部反相吸附剂用于清除配位生物材料等。
Alkyl-bonded sorbents have been mainly studied for SPE in inorganic analysis; our attention in this paper will be focused on such materials. The most simple mode of metal preconcentration by SPE is based on the addition of a soluble complexing reagent to the test solution, followed by the adsorption of metal complexes formed on an alkyl-bonded material. Another mode in SPE involves a preliminary dynamic modification of a similar adsorbent, e.g. by a solution of a chelating agent, which is retained at the material surface during the following separation process due to non-covalent interactions. Thus-prepared sorbents possess the properties of materials bearing covalently-bonded chelating functions. Both modes of SPE are examined in this paper.
对烷基键合的吸附剂的研究主要针对SPE在无机分析中的应用;这篇文章中我们的注意力将集中在这类材料上。用SPE进行金属预浓缩的最为简单的模式是向测试溶液中加入可溶性配位试剂,随后将金属配合物吸附在烷基键合的材料上。SPE的另一个模式包括对类似吸附剂的预先动力学改性,例如利用鳌合剂溶液,由于非共价相互作用,鳌合剂在随后的分离过程中将会固定在材料表面。这样制备的吸附剂的性质与承载共价键连接鳌合官能团材料的性质相同。本文总结了这两种SPE模式。
Like most of separation methods, SPE is based on the distribution of a solute between two phases. Both batch and column variants of SPE can be used for preconcentration purposes. The column mode can be considered as a version of reversed phase liquid–solid chromatography (RP LSC).13 In fact, alkyl-bonded stationary phases with the alkyl length nc= 8, 16, or 18 and different grain sizes are most often used.Chromatographic retention is conveniently described by the capacity factor, k, which is defined as ki = qi,s /qi,m , where q i,sand qi,m denote the total quantity of a solute (i) to be present in the stationary phase (s) and the mobile phase (m), respectively.14,15 The higher is the k value, the better is the solute retained, and the later is eluted from the column. Correspondingly, the separation selectivity can be defined as the relative retention of βi,j , which is sometimes called the separation factor,expressed in terms of the capacity factors,βi,j = kj /ik. If the preconcentration of a group of dissolved ions or molecules is required, the k values for all of the solutes should be as close as possible.
与大部分的分离方法相同,SPE是根据溶质在两相之间的分配。SPE的批变量和柱变量均可用于预浓缩。柱模式可以看作是反相液-固色谱(RP LSC)的改进。事实上,烷基链长度nc=8、16或18以及各种颗粒尺寸的烷基键合固定相最为常用。色谱保留能力通常用容量因子k描述,定义为ki = qi,s /qi,m,其中qi,s和qi,m分别指溶质(i)在固定相(s)和流动相(m)中的含量。K值越高,溶质的保留能力越高,从柱中流出的越晚。相应的,分离选择性可以定义为相对保留能力βi,j,有时也被称作分离因子,用容量因子来表达,βi,j = kj /ik。如果需要预浓缩一组溶解的离子或分子,所有溶质的k值应当尽可能接近。
