原文由 千层峰(jxyan) 发表:
安捷伦增强型脂质去除产品,是什么来的?没看懂
Recommended Protocols for
Enhanced Matrix Removal - Lipid
Technical Overview
Introduction
QuEChERS and protein precipitation are widely accepted and adopted sample prep
methods in the food market as well as many others. Removal of lipids is highly
desirable as they diminish method performance and instrument lifetime by introduc-
ing interferences, depositing in the analytical flow path, and causing matrix effects
in mass spectrometry.
The need for lipid removal is well understood, but current methods often sacrifice
analyte recovery, removing some of your target analytes along with the lipids.
Now, you do not have to choose between lipid removal and analyte recovery,
because Bond Elut QuEChERS Enhanced Matrix Removal-Lipid delivers the most
complete lipid removal and analyte recovery of any sample prep product.
Enhanced Matrix Removal-Lipid (EMR-Lipid), unlike any other type of sample prep, is
a unique sorbent that selectively removes lipids in complex matrices, so you can
remove lipids without losing your analytes.
In addition, EMR-Lipid uses a convenient dispersive solid phase extraction (dSPE)
format, allowing you to simply drop it into your current sample preparation workflow.
The innovative EMR-Lipid technology efficiently removes lipids from a wide range of
samples using a single sorbent material, regardless of the sample fat content.
Standard protocols will eliminate the need for extensive method development
previously needed to handle samples with fatty matrices. Predefined protocols also
lessen the need for rigorous training and documentation, reducing complexity and
streamlining lab productivity to reduce operating cost.
