原文由 redanqi 发表:
原文由 happyjyl 发表:
原文由 laozou 发表:
有没有人翻译好第九部分“试验周期和结果的评价”啊?比较急需这一部分
晚上回去帮你看看.
第九部分比较长,要不要一人一半
晕,我刚才刚注册,2小时还不能发贴。10部分好了,如下,部分专业词组难免不准确,请给予指导:
10. Report
10.1 Report the following information:
10.1.1 Type and model of exposure device.
10.1.2 Type of light source.
10.1.3 Average distance from specimens to light source.
10.1.4 Age of lamps at the beginning of the exposure, and
whether any of the lamps were replaced during the period of
exposure.
10.1.5 Type of black panel (uninsulated or insulated) used.
10.1.6 If required, report irradiance measured at a single
wavelength in W/(m2·nm) and radiant energy for a single
wavelength in J/(m2·nm). Report irradiance measured in a
broad band, such as 300-400 nm, in W/m2 with the spectral
region specified. Report radiant energy measured in a broad
band as J/m2 with the spectral region specified.
10.1.6.1 Do not report irradiance or radiant exposure unless
direct measurement of irradiance was made during the exposure.
10.1.7 Elapsed exposure time.
10.1.7.1 When required, report any test interruptions greater
than 24 h in accordance with 7.10.
10.1.8 Light and dark-water-condensation cycle employed.
10.1.9 Operating black panel temperature.
10.1.10 Operating relative humidity during light exposure
(if measured).
10.1.11 Specimen repositioning procedure (if different from
that described in 8.4).
10.1.12 Results of property tests. Where retention of
characteristic
property is reported, calculate results according to
Practice D 5870.
10 报告
10.1 报告需包括以下信息:
10.1.1 试验装置的类型和型号,
10.1.2 光源的类型,
10.1.3 样品与光源间的平均距离,
10.1.4 试验开始时灯管(泡)的使用时间,以及在试验期间是否更换新灯管(泡).
10.1.5 使用的黑色面板的类型(隔热或是不隔热).
10.1.6 如果有要求,报告测定的某一波长的相对光谱功率[W/(m2·nm)]和某一波长的光辐射能[J/(m2·nm)].此值需由在较宽的波长范围,如300~400 nm,光谱区测定的辐射照度(W/m2)计算.辐射能是由在较宽的波长范围测定的光谱区辐照量[J/m2]计算.
10.1.6.1 除非在试验中对光谱进行了直接测定,否则不应报告光谱功率或辐射能.
10.1.7 试验耗时,
10.1.7.1 如有要求,参照7.10所述,报告应说明中断时长超过24 h的试验的情况,
10.1.8 光/暗水浓缩周期
10.1.9 操作黑色面板的温度.
10.1.10 光试验(如测定)操作期间的相对湿度.
10.1.11 说明样品重新配置的程序(如果与8.4所述不同).
10.1.12 属性测试结果.在持久力属性报告处,需按D5870计算结果.
