主题:【求助】翻译英国BS5852阻燃测试标准
浏览0 回复15 电梯直达
jimmyli
该帖子已被happyjyl设置为精华;
各位高手大家好:
    本人求助BS5852翻译阻燃测试标准,先谢谢各位高手及版主翻译,我相信会有很多做纺织品朋友对这份标准会有兴趣的,我会逐会发表上来给大家了解,以便大家工作和学习。谢谢大家,另本很想多交些纺织阻燃测试和家具测试的朋友。
翻译内容如下:
The furniture and furnishings (fire)(safety)regulations 1988
                          SCHEDULE 1
Regulations 3,6 and 7
Ignitability test for polyurethane foam in slab or cushion form .
1.    The foam shall be tested in accordance with the method set out in BS5852 :part 2 using cover fabric corresponding to the specification set out in paragraph 2 below
2.    The fabric shall be made of 100 per cent flame retardant polyester fibre.its construction shall be woven to a plain weave.the yarn in the warp shall be of 1.6 decitex fibre ,spun to a linear density of 37 tex, z twist at 420turns per metre .the fabric shall be woven to 20.5 yarn threads per centimeter in the warp.
The yarn in the weft shall be of 3.3 decitex fibre spun to a linear density of 100 tex,z twist at 550 turns per metre .the fabric shall be woven to between 12.6 and 13 threads per centimeter in the weft .
3.    The test rig as specified in clause 6.1.1 of BS5852 :PART 2 shall have expanded steel platforms of not less than 28x6 mm  mesh size.the test rig is placed on a metal tray of sufficient dimensions to collect any debris falling from specimens being tested. the rig and debris tray shall be mounted of a weighing balance with a remote readout having a full – scale deflection of at least 0 to 20 kg to an accuracy of 2 g .
4.    The foam under test ,cut to the specified dimensions is placed on the test rig ,covered with the fabric specified in paragraph 2 above and tensioned with clips as set out in BS 5852 :part 2.an ignition source 5 crib is placed in position .the mass of the  complete assembly is determined (“initial mass”).the test shall be carried out in accordance with BS5852:part2.in particular flaming or smouldering failure shall be determined against the criteria of clause 4 of BS 5852”PART 2.
After flaming and smouldering has ceased.,any debris which has become detached from the specimen shall be removed .the remaining mass of the assembly (final mass”)is then recorded.
5.    if failure against the criteria of clause 4 of BS 5852 :part 2 has occurred but only by way of damage exceeding the limits defined in clauses 4.1 (e),4.1(f)and 4.2(f)and provided that the resultant mass loss (initial mass less final mass)is less than 60 gthe foam passes the ignitability test .
                              PART II
Ignitabilitytest for polyurethane foam in crumb form.
1.    The foam shall be tested in accordance with the method set out in BS5852 :part 2using cover fabric corresponding to the specification set out in paragraph 2 below
2.    The fabric shall be made of 100 per cent flame retardant polyester fibre .its construction shall be woven to a plain weave .the yarn in the warp shall be of 1.6 decitex fibre ,spun to a linear density of 37 tex ,z twist at 420 turns per metre. .the fabric shall be woven to  20.5 yarn threads per centimeter in the warp.
The yarn in the weft shall be of  3.3 decitex fibre spun to a linear density of 100tex,z twist at 550 turns per metre .the fabric shall be woven to between 12.6 and 13 threads per centimeter
in the weft .
The fabric finish shall be scoured and heat set .its mass shall be 220 g per ㎡ plus or minus 5 per cent .
3.    The test rig panels are lined with the fabric specified in paragraph 2 above .sufficient crumb foam shall be placed upon the seat and bace panels so that when the cover fabric piece is placed over them ,both are stuffed of the density used in the furniture as intended.the test carried out in accordance with BS5852 :PART 2 using ignition source 2 as specified therein.
4.    If smouldering of flaming failure against the criteria of clause 4 of BS 5852 :part 2 has not occurred or has occurred only by way of damage exceeding the limits defined in clauses 4.1 (e),and 4.2 (f),the crumb foam passes the ignitability test .
                  PART III
Ignitability test for latex rubber foam.
1.    The foam shall be tested in accordance with the method set out in BS5852:Part 2 using cover fabric corresponding to the specification set out in paragraph 2 below.
2.    The fabric shall be made of 100 per cent flame retardant pllyester fibre .its construction shall be woven to a plain weave . the yarn in the warp shall be of 1.6 decitex fibre,spun to a linear density of 37 tex ,ztwist at 420 turns per metre .the fabric shall be woven to 20.5 yarn threads per centimeter in the warp.
The yarn in the weft shall be of 3.3 decitex fibre spun to a linear density of 100 tex ,z twist at 550 turns per metre.the fabric shall be woven to between 12.6 and 13 threads per centimeter in the weft..
The fabric finish shall be be scoured  and heat set .its mass shall be 220 g per ㎡ plus or minus 5 per cent .
3.    The foam under test cut to the specified dimensions is placed on the test rig, covered with the fabric specified in paragraph 2 above and tensioned with clips as set out in BS5852:part 2 .The test is then carried out using ignition source 2 as specified therein.
4.     If smouldering or flaming failure against the criteria of clause  4 of BS 5852 :PART 2 does not occur ,the latex rubber foam passes the ignitability test.
happyjyl
家具和家饰(防火)(安全)条例 1988
Ignitability test for polyurethane foam in slab or cushion form.
以厚片或衬垫的方式进行聚氨酯泡沫体可燃性测试
1.        The foam shall be tested in accordance with the method set out in BS5852 :part 2 using cover fabric corresponding to the specification set out in paragraph 2 below.
应采用第2段中相应的套布,按照标准BS5852第二部分对泡沫体进行测试。
cover fabric:如沙发套、火车上的坐垫套等。
2.    The fabric shall be made of 100 per cent flame retardant polyester fibre. its construction shall be woven to a plain weave. the yarn in the warp shall be of 1.6 decitex fibre ,spun to a linear density of 37 tex, z twist at 420turns per metre .the fabric shall be woven to 20.5 yarn threads per centimeter in the warp.
套布应采用100%防火聚酯纤维制造。应为平纹结构。经纱应采用1.6分特的纱,纺成线密度为37特的纤维后Z捻成每米420圈,(然后)织成每厘米20.5支纱线。
the yarn in the warp 在这里应该是Warp yarn (经纱)的意思,对应的是Fill yarn (纬纱)。
Tex:特。是用来计量纤维和纱粗细的国际单位,等于1万米纤维或纱的重量(以克为单位)。deci-这个前缀表示十分之一,所以Decitex是“分特”,等于1000米纤维或纱的重量(以克为单位),简称Dtex。
Z-twist:Z捻。纱线的捻向从左下角倾向右上角,倾斜方向与“Z”的中部相一致。与之对应的是S捻 S-twist. 纱线的捻向从右下角倾向左上角,倾斜方向与“S”的中部相一致。
jimmyli
谢谢版主啊:
    可否在按原文下翻译啊!以便参考啊!十分感谢版主的支持。
happyjyl
原文由 jimmyli 发表:
谢谢版主啊:
我也很想,但是时间精力有限啊。这个月有两个考试,我现在一门考试的课程只看了不到一半,另一门还没开始看
czq8
1988年的标准,也许按照这个名字,有类似的咱们国家的标准了,性能指标差不多的。
zhw19780614
czq8
GA 303-2001 软质阻燃聚氨酯泡沫塑料
标准号: GA 303-2001
中文标题: 软质阻燃聚氨酯泡沫塑料
英文标题: Soft fire retardant polyurethane foam plastics
这是一个类似的标准
因为不懂纺织品,译文仅供参考,原文也有词句错误,用的时候小心。
家具和内饰材料(火灾)(安全)规定:1988年
SCHEDULE 1
规范  1
规定3,6和7
板状或垫状聚氨酯泡沫体的点燃性试验
1. The foam shall be tested in accordance with the method set out in BS 5852: part 2 using cover fabric corresponding to the specification set out in paragraph 2 below.
1. 泡沫体应该使用覆盖织物,按照英国标准BS 5852第2部分中规定的方法进行试验,覆盖织物应该符合下面第2段中所规定的技术要求。
2. 该织物应该由100%阻燃聚酯纤维制成。
其结构应该是编织成平纹组织。
the yarn in the warp shall be of 1.6 decitex fibre, spun to a linear density of 37 tex, z twist at 420 turns per metre.
经纱内的纱线应该选用1.6分特(decitex)纤维,纺成线密度为37特(tex), Z捻为420转/每米。
织物应该纺织成,在经线上每厘米20.5纱线支纱线。
The yarn in the weft shall be of 3.3 decitex fibre spun to a linear density of 100 tex, z twist at 550 turns per metre. the fabric shall be woven to between 12.6 and 13 threads per centimeter in the weft.
纬纱应该选用3.3分特纤维,纺成线密度100特,在每米550转Z捻。织物应该纺织成,在纬线方向每厘米12.6和13支纱线。
3. The test rig as specified in clause 6.1.1 of BS 5852: PART 2 shall have expanded steel platforms of not less than 28x6 mm mesh size.
3.英国标准BS 5852第2部分第6.1.1条中规定的试验夹具,应该具有不少于28×6毫米筛孔的展开钢质平台。
把试验夹具放入一个足够尺寸的金属盘内,以便收集试验样品上掉拉来的任何碎屑状物质。
the rig and debris tray shall be mounted of a weighing balance with a remote readout having a full – scale deflection of at least 0 to 20 kg to an accuracy of 2 g.
夹具和碎屑托盘应该安装在一个带有遥距读数计的称量天平上,天平的满刻度偏转度至少为0到20千克,精确度为2克。
4. The foam under test, cut to the specified dimensions is placed on the test rig, covered with the fabric specified in paragraph 2 above and tensioned with clips as set out in BS 5852: part 2.
4. 试验中的泡沫体,被切割成规定尺寸,放入试验夹具上,根据英国标准BS 5852第2部分中的规定,使用上述第2段中规定的织物覆盖,使用夹子拉紧。
an ignition source 5 crib is placed in position.
把5号点火源放在适当位置上。
测定整个组件的质量(“起始质量”)。
the test shall be carried out in accordance with BS 5852: part 2.
应该按照英国标准BS 5852第2部分进行试验。
in particular flaming or smouldering failure shall be determined against the criteria of clause 4 of BS 5852: PART 2.
应该依照英国标准BS 5852第2部分第4条的判据,确定特殊的火焰或阴燃破坏。
After flaming and smouldering has ceased, any debris which has become detached from the specimen shall be removed.
火焰和阴燃完全停止之后,应该移去从样品上脱落的所有碎屑。
the remaining mass of the assembly (final mass) is then recorded.
然后,记录组件的剩余质量(最终质量)。
5. if failure against the criteria of clause 4 of BS 5852: part 2 has occurred but only by way of damage exceeding the limits defined in clauses 4.1 (e), 4.1(f) and 4.2 (f) and provided that the resultant mass loss (initial mass less final mass) is less than 60 g the foam passes the ignitability test.
5. 如果根据英国标准BS 5852第2部分第4条的判据发生了破坏,但是仅仅是以超过了第4.1(e)、4.1(f)和4.2(f)规定范围的损坏,并且如果产物的质量损失(初始质量少于最终质量)小于60克,该泡沫体通过了点燃性试验。
PART II
第II部分
Ignitability test for polyurethane foam in crumb form.
团块状聚氨酯泡沫体的点燃性试验
1.泡沫体应该使用覆盖织物,按照英国标准BS 5852第2部分中规定的方法进行试验,覆盖织物应该符合下面第2段中所规定的技术要求。
2.该织物应该由100%阻燃聚酯纤维制成。
其结构应该是编织成平纹组织。
纬线应该选用3.3分特(decitex)纤维,纺成线密度为100特(tex), Z捻为550转/每米。
织物应该纺织成,在纬线上每厘米之间12.6和13支纱线之间。
The fabric finish shall be scoured and heat set.
织物表面应该洗刷和热定形。
its mass shall be 220 g per ㎡ plus or minus 5 per cent.
其质量应该为每平方米220克±5%。
3. The test rig panels are lined with the fabric specified in paragraph 2 above.
3. 试验夹具板使用上述第2段中规定的织物衬里。
sufficient crumb foam shall be placed upon the seat and bace panels so that when the cover fabric piece is placed over them, both are stuffed of the density used in the furniture as intended.
在座位和基板上应该放置足够的团块状泡沫体,以便在覆盖织物片放置在他们之上时,他们都被填塞到打算用于家具的密度。
the test carried out in accordance with BS 5852: PART 2 using ignition source 2 as specified therein.
应该按照英国标准BS 5852第2部分,使用其中规定的2号点火源,进行实验。
4. If smouldering of flaming failure against the criteria of clause 4 of BS 5852: part 2 has not occurred or has occurred only by way of damage exceeding the limits defined in clauses 4.1 (e), and 4.2 (f), the crumb foam passes the ignitability test.
4.如果根据英国标准BS 5852第2部分第4条的判据,没有发生火焰的阴燃破坏,或仅仅是超过了第4.1(e)和4.2(f)规定范围的损坏,该团块状泡沫体通过了点燃性试验。
PART III
第III部分
乳胶橡胶泡沫体的点燃性试验
1. The foam shall be tested in accordance with the method set out in BS 5852: Part 2 using cover fabric corresponding to the specification set out in paragraph 2 below.
2. The fabric sh
该帖子作者被版主 redanqi10积分, 2经验,加分理由:热心应助
liangbp
jimmyli
风间叶子
papanbird
A.Furniture and Furnishing (Fire Safety) Regulation
1988英国家俬及家具防火安全条例1988
a)Ignitability test for polyurethane foam in slab or cushion form    块状海棉    Schedule 1 Part I
BS 5852 part 2:1982 Ignition Source 5
b)Ignitability test for polyurethane foam in crumb form  碎状海棉    Schedule 1 Part II
BS 5852 Part 2:1982 Ignition Source 2
c)Ignitability test for polyurethane foam in latex rubber foam  公仔棉    Schedule 1 Part III
BS 5852 Pt 2: 1982 Ignition Source 2
d)Ignitability test for non-foam filling materials singly
非海棉类     Schedule 2 Part I
BS 5852 Part 2: 1982 Ignition Source 2
e) Test for cover material-all types
面料测试
                      Schedule 4 Part I
BS 5852 Part 1:1979 Ignition Source 0
with water soak
Schedule 5 Part 1
BS 5852 Part 1:1979 Ignition Source 1
with water soak
f) Test for platform cloth and dust cover material
防尘布                 Schedule 4 Part II
BS 5852 Part 1: 1979 Ignition Source 0
Schedule 5 Part III
BS 5852 Part 1: 1979 Ignition Source 1
g) Test for interliner
里布
        Schedule 3
BS 5852 Part 2: 1982 Ignition Source 5
with water soak
版主提示:严禁在技术版面做广告。
