主题:【分享】VCD30-D12-T512三路输出隔离式DC-DC电源模块CUI
浏览0 回复0 电梯直达
Ins_53b266b9
VCD30-D12-T512三路输出隔离式DC-DC电源模块CUI,277,272
  VCD30-D12-T512是CUI公司的一个三路输出隔离式DC-DC电源模块,具有以下特点:
  输入电压范围:9-18VDC
  输出电压和电流:
  第一路输出:5VDC,最大电流3500mA
  第二路输出:±12VDC,最大电流±310mA
  空载电流:35mA
  满载效率:79%
  主要技术特点:
  1. 电压精度:
  单路输出:±2.0%
  双路输出:±2.0%
  三路输出:±2.0%
  2. 隔离电压:500VDC
  3. 开关频率:300kHz
  4. 工作温度范围:-25°C到+71°C
  5. 存储温度范围:-55°C到+105°C
  6. 短路保护:连续
  7. 尺寸:2x2x0.4英寸 (50.8x50.8x10.2mm)
  8. 外壳材质:黑色涂层铜,带非导电底座
  该模块适用于需要稳定多路电压输出的应用,具有较高的转换效率和宽工作温度范围,特别适合工业自动化、通信设备等需要高可靠性电源的场合。
相关型号参数:
mode
number
  input
  voltage
output
voltage
output input current
currentno loadfull loadefficiency
VCD30-D12-S3R3  9-18VDC3.3VDC5000mA30mA1860mA74%
VCD30-D12-S5  9-18VDC5VDC5000mA30mA2675mA78%
VCD30-D12-S12  9-18VDC12VDC2500mA30mA3050mA82%
VCD30-D12-S15  9-18VDC15VDC2000mA30mA3050mA82%
VCD30-D12-D5  9-18VDC±5VDC±2500mA35mA2675mA78%
VCD30-D12-D12  9-18VDC士12VDC±1250mA35mA3050mA82%
VCD30-D12-D15  9-18VDC±15VDC±1000mA35mA3050mA82%
VCD30-D12-T512  9-18VDC  5/±12VDC3500/±310mA35mA2640mA79%
VCD30-D15-T515  9-18VDC  5/±15VDC3500/±250mA35mA2640mA79%
VCD30-D24-S3R3 18-36VDC3.3VDC5000mA30mA920mA75%
VCD30-D24-S5 18-36VDC5VDC5000mA30mA1336mA79%
VCD30-D24-S12 18-36VDC12VDC2500mA30mA1525mA82%
VCD30-D24-S15 18-36VDC15VDC2000mA30mA1525mA82%
VCD30-D24-D5 18-36VDC±5VDC±2500mA30mA1336mA79%
VCD30-D24-D12 18-36VDC±12VDC±1250mA30mA1470mA85%
VCD30-D24-D15 18-36VDC士15VDC±1000mA30mA1470mA85%
VCD30-D24-T512 18-36VDC5/±12VDC3500/±310mA30mA1320mA80%
VCD30-D24-T515 18-36VDC5/±15VDC3500/±250mA30mA1320mA80%
VCD30-D48-S3R3 36-72VDC3.3VDC5000mA20mA460mA75%
VCD30-D48-S5 36-72VDC5VDC5000mA20mA660mA79%
VCD30-D24-S12 36-72VDC12VDC2500mA20mA765mA82%
VCD30-D48-S15 36-72VDC15VDC2000mA20mA765mA82%
VCD30-D48-D5 36-72VDC±5VDC±2500mA25mA660mA79%
VCD30-D48-D12 36-72VDC±12VDC±1250mA25mA735mA85%
VCD30-D48-D15 36-72VDC士15VDC±1000mA25mA735mA85%
VCD30-D48-T512 36-72VDC5/±12VDC3500/±310mA25mA655mA80%
VCD30-D48-T515 36-72VDC5/±15VDC3500/±250mA25mA655mA80%
CUI是美国BEL旗下公司,主要提供AC-DC和DC-DC电源模块产品。深圳立维创展科技有限公司代理销售CUI品牌产品,欢迎咨询。
